Cam installation tips/suggestions
I would imagine that tool would save lots of time. Took me about a good four hours to change them all (with complications). I was doing the "rotate-the-engine and let the valve hit the piston method" and almost lost a valve. Turns out the crank dampener or whatev is on the front must've been taken off and not re-aligned.
What method did you use to hold the lifters up?
Good thing you didn't lose that valve!
I did however just for document sake buy 16 pen magnets and attempt that way. It was pretty scary. Here is a picture:
You can even see how I put the bolts in the cam.
Used the same tim's tool and it worked perfect.
The dowel rod method DID NOT work on either motor. We got the recommended size from on here and you can see (if you shine a light in) that the rods do diddly squat for holding lifters.
Shiv, you're saying that the lifter can fall with the dowels in?
He would get on the opposite side of the car and hold the spring down while I attempted to get the locks in. That was if you didn't drop them or someone lost their grip. Sometimes I would hold and sometimes he would hold, PITA holding down the PRC golds for any amount of time if the locks are being stubborn.
We used a small Craftsman compressor to hold the valves up. Good thing about that is, it let me know cylinder 7 rings allow alot of bypass, yay!!
Also helps to tap the top of the valve/retainer with a rubber mallet when you are starting to compress the spring, it helps free the locks up. Sometimes it would just compress the entire valve before the locks would come out.
DON'T DROP THE OIL PICKUP BOLT if you change your oil pump. I did, that was not fun. Ended up draining 700 mile oil...
Get a BIG breaker bar for crank bolt.
I'm giving myself three days to do the job. Four years ago it took me three days to swap heads, cam and intake on my vette.
If it takes a little longer, oh well. I understand when you rush stuff like this, you end up messing something up.
The worry with the magnet method (and especially on a warm motor) is that it can heat the glue up holding the tips on and they get stuck to the lifter...yikes. My motor was nearly hot still when I did that.
if I had to do it over again, I would have started on the passenger side first. The driver's side is not nearly as bad.
I dropped the starter (out of curiosity but had to be done anyway) to see how to lock the flywheel to remove the crank pulley. All I saw was teeth. How do I secure the flywheel with a screwdriver? I was hoping I'd see some holes in the flywheel to stick a screwdriver through, though I didn't turn the motor over to see.
One thing I have a question about, on LS1howto it dosen't say anything about sealing the timing chain cover by lowering the oil pan a little. Does this have to be done?
At least I think the hardest part of the install is done.
