Doing a H/C/I swap on an LS1, have a compression question
Old Jun 29, 2010 | 12:01 AM
cabech984's Avatar
Default Doing a H/C/I swap on an LS1, have a compression question
I'm doing a head and cam swap to a 1998 Formula. It has stock pistons. Using a set of 59cc PRC Stage 2.5 5.3L cylinder heads(w/ recessed valves) and a stock MLS gasket, what compression am I looking at having here?
I've calculated approx 11.3:1 but I want some pro's expertise.
I'm double checking but I believe I'm going to need 7.4" pushrods. Any input on this?
Old Jun 29, 2010 | 12:04 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Depending on your cams base circle and shaved heads with stock gaskets it may not be a 7.400.
How did you get 11.3:1?
(I am not a pro by any means) Just wanted to see your math.
Old Jun 29, 2010 | 12:30 AM
cabech984's Avatar
I just used an online calculator but I did it without complete knowledge of the compressed thickness of the HG and other head gasket info needed for the calculator.
Old Jun 29, 2010 | 12:40 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It wouldnt happen to be the one where you have to send paypal to use was it?
Old Jun 29, 2010 | 12:43 AM
93sspcoupe's Avatar
there is a formula to figure up the cr, but i dont remember what it is.
what is the stock heads combustion chamber size and stock cr?
Old Jun 29, 2010 | 12:46 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
61.15cc is stock on the 5.3 head IIRC.
Old Jun 29, 2010 | 12:52 AM
93sspcoupe's Avatar
i wouldnt think your cr would be that high but i could be wrong.
Old Jun 29, 2010 | 01:02 AM
cabech984's Avatar
No it wasnt
Old Jun 29, 2010 | 01:06 AM
Paint_It_Black's Avatar
11.46 according to Pipemax
.051 compressed thickness, 59cc chamber, 3.915 gasket bore diameter, 3.898 cylinder bore, piston out of the hole .007
Old Jun 29, 2010 | 01:25 AM
cabech984's Avatar
Hmm thats weird. I came up with this after using one of the compression ratio calculators out there in google land. I just would like an approximate CR number.
Bore Size: 3.9"
Stroke: 3.662
Combustion Chamber: 59cc's
Compressed HG: .048"
Dome/Dish: 0
Deck: .007
HG Bore Dia: 3.915"
I did this into a calculator and came up with 11.26:1
Old Jun 29, 2010 | 02:03 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Bore Size: 3.9"
Stroke: 3.662
Dome/Dish: 0
Deck: .007
HG Bore Dia: 3.915"
has this stock block been bored a tad?
