Tried searching.... Help please!!!
got a 2000 ws6, need to replace my timing chain and am gonna use the ls2 timing chain but am having a hard time finding part numbers
i was told i needed:
oil pump o-ring
water pump gasket
timing cover gasket
main seal
and the ls2 chain
what else would i need to do this and can anyone help me with part numbers?
oil pump o-ring
water pump gasket
timing cover gasket
main seal
and the ls2 chain
oil pump o-ring
water pump gasket
timing cover gasket
front seal
and the ls2 chain
oil pump o-ring
water pump gasket
timing cover gasket
front seal
and the ls2 chain
Call a sponsor>>>>>
Texas Speed has everything you need.
If you just need the LS2 chain:
http://www.texas-speed.com/shop/item...d=620&catid=53
For pulley bolt, front seal, and all the gaskets, just get a cam change kit:
http://www.texas-speed.com/shop/item...id=85&catid=36
that was my other concern, i was gonna order from summit cause they ship really really fast but they cant seem to find everything i need. those links you put up seem to have everything i need except the (oil pump pick up o-ring)
just need to find that part and i will be ready to go
