With X1 Cam How do I get Compression back up to 11
Old Jan 19, 2004 | 07:02 PM
Pro Mouse's Avatar
Question With X1 Cam How do I get Compression back up to 11
With the x1 cam with 59 cc combustion chambers raise me up to 10.8 to 11-1 Compression Ratio on a stock bottom end 99 LS1???Bare with me I am new to this
Thanks
Old Jan 19, 2004 | 07:35 PM
jimmyblue's Avatar
Moderator
Don't bother with cranking compression measurements
on a high overlap cam. Your CR at higher RPM is what
it was (more like numerical CR). Cam only affects the
accuracy of the cranking compression test, for the
worse, because both valves are open and you lose a
little of the compression stroke - when the piston is
moving slow. You get it back, up top.
Old Jan 19, 2004 | 07:57 PM
jrp's Avatar
jrp
SN95 Director
english
Old Jan 19, 2004 | 10:18 PM
Colonel's Avatar
He means that with increased overlap your cranking cylinder pressure (what your cylinders see when you do a compression check with a gage) decreases. But, your dynamic (moving) cylinder pressure is usually higher at higher RPMs (making more power) with increased cam duration (all else being equal.) Still with me? Good. Your static (not moving), or calculated CR will be the same regardless of the cam.
Old Jan 19, 2004 | 11:00 PM
Damian's Avatar
LSX Mechanic
Something else to consider. LSA/ICL will also play a factor in dynamic, or overall compression.....For example...
A cam on a 112 LSA with an added 4 degrees of advance would be on a 108 ICL. This allows for LESS bleedoff, therefor increasing cranking compression and dynamic. The same exact cam on a 112 LSA with no advance, would be on a 112 ICL, bleed off much more cylinder, and reduce overall dynamic levels...
Kind of confusing @ first, but gets easier to understand..
josh
Old Jan 20, 2004 | 06:34 PM
Pro Mouse's Avatar
So Running Patriot Stage 2 LS6 heads (59cc)and a X1 cam would make a good Combo?
