6.0 in a dragster......
I have a 2001 6.0 block, crank pistons and rods with only 3k miles, 853 heads and i would like to put something together to drop it in a dragster but i am looking for about 450 to 500 horses. Any combinations? Since life is tuff at this time, i am looking into somekind of a low budget.
Thanks in advance,
57
Are you planning on staying FI or going carb?
Either way, a set of aftermarket rod bolts will let you spin it with some peace of mind, and with a carbed intake will also let you use its intended rpm range.
I saw this car going 8.40's on youtube. Not bad!....and even a 12 bolt chevy rear.
I have a Dana 60 for mine with 40 spline axles and titanium spool. Heavy but for the price can not beat it.
243's don't need a crazy split cam to work properly, and can be had far cheaper than a set of l92's. I like the L92's, but not for a total budget build.
