stock timing chain
Old Jan 20, 2004 | 11:26 AM
taqwache's Avatar
Default stock timing chain
is anyone running the stock timing chain with .600+ lift and dual springs. am i looking for trouble or is the stock one reliable. also how good is that JWIS chain with the stock gears?
Old Jan 20, 2004 | 12:51 PM
HOTROD98Z's Avatar
I had a thread going about this a couple of weeks ago. There were quite a few guys that were running a stock chain on their H/C motors and some were even spraying on top of that. None of them had any failures or problems to report, so i will probably go with a stock chain as well when i do my install.
Old Jan 20, 2004 | 01:41 PM
Tally TransAm's Avatar
new stock chain here. crane duals and a .581 lift cam, will soon be running a new cam with lifts in the 590's
Old Jan 20, 2004 | 02:58 PM
taqwache's Avatar
that sounds cool. i guess i will be using the stocker in order to meet my deadline. later on i will swap it out. i have only heard of a couple breaking but not many.
Old Jan 20, 2004 | 03:05 PM
gomer's Avatar
Stock chain here... abused daily.
Old Jan 20, 2004 | 06:15 PM
01_SuperSlow's Avatar
LG says they use the stock chain in most G5X2 cam installs. 232/240 .595/.609
I will most likely be going with the stock chain when I install my G5X2.
I'm now going to sit back and watch all Rollmaster Double Roller Chain fans chime in and turn this into a flamewar .
Old Jan 20, 2004 | 07:20 PM
Jackal_49's Avatar
I haven't heard of any failures either, but if I were going to do a cam change you are right there anyways. You should change it over to the double roller chain. That's called cheap insurance.
Old Jan 20, 2004 | 07:26 PM
jrp's Avatar
jrp
SN95 Director
Old Jan 20, 2004 | 08:00 PM
monkeyboy's Avatar
awww bullshit... you dont need a timing chain at all. pull that monkey off. hahaha
Old Jan 20, 2004 | 08:07 PM
taqwache's Avatar
hey that is a good idea. i never though of that. this will give me less weight that the engine has to spin and i will get tons of more power. hehehehehe.
Old Jan 20, 2004 | 08:34 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Stock chain here with no worries.
