How do you repair a scratched block?
Old Jul 24, 2010 | 11:11 AM
Steve Gunn's Avatar
Default How do you repair a scratched block?
I smacked it a couple of times with the header flange. I'm getting ready to put the heads back on. Any advice?
Thanks!
Old Jul 24, 2010 | 11:20 AM
spdygon's Avatar
that is not good, the one in between the water jacket and sleeve.
have no idea.
good luck!
Old Jul 24, 2010 | 11:37 AM
nysbadmk8's Avatar
Lightly sand it to take the edge down... use a gm MLS gasket with a copper spray on it.. hope for the best.
Old Jul 24, 2010 | 11:38 AM
Gordon0652's Avatar
Copper spray wont take care of that one. Maybe?
You could take the block out and have it refinished.
MLS!
Old Jul 24, 2010 | 02:11 PM
SilverSS's Avatar
That's not bad. The scratch isn't all the way though. Just smooth it out and use an MLS gasket with a bore size that will cover the sleeve. Use copper spray. I put my motor together with a scratch like that and never had a problem.
Old Jul 24, 2010 | 02:20 PM
chaman's Avatar
Okay...maybe I will get flamed but Ive seen (and know( that some scratches like this have been repaired with epoxy. You know the one that is sold at Autozone, Pep Boys and the like, called JB-Weld. Thing is quite good and resistant too. No problems reported.
Old Jul 24, 2010 | 03:09 PM
nysbadmk8's Avatar
JB is great.. but for this application its not going to cut it.
Old Jul 24, 2010 | 03:40 PM
AsaSpades's Avatar
Deff not a solution I would look to, deff get that head lapped at least, or resurfaced
Old Jul 24, 2010 | 04:41 PM
garygnu's Avatar
just use some fine sand paper and smooth down the ridges.
Old Jul 24, 2010 | 05:40 PM
chaman's Avatar
Ive seen it "cut it". But anyways dont do what I said if you are not convinced, follow the advice of a good engine builder.
Old Jul 24, 2010 | 06:22 PM
NVR_SPDS's Avatar
dont sand it.. i would use a fine file to take the edges down. that way you lower your risk of low spots.
Old Jul 24, 2010 | 06:45 PM
cookseyb's Avatar
J B weld with the iron filings is good to 600 degrees File it flat clean with solvent then skim it with the J B weld, good to go!
Old Jul 24, 2010 | 06:54 PM
chaman's Avatar
Old Jul 24, 2010 | 07:05 PM
Steve Gunn's Avatar
Thanks for all of the responses. Great input. The motor is NOT coming out. (Check my photobucket for pics of the install in my tiny garage) I'll put a match to it before I yank that thing again!!
I understand what will happen if I create a low spot. The filler idea is interesting...
Old Jul 24, 2010 | 10:58 PM
Duffster's Avatar
I'd cheap out and lightly tap on it with a flat-faced hammer until it were low and then sand it. . .LIGHTLY TAP...
Old Jul 25, 2010 | 09:59 PM
massls1guy's Avatar
If you're not running nitrous or boost I would go with the GM graphite gasket, more forgiving to imperfections.
edit: sorry, saw you do run nitrous in your mod list.
