F1 cam install complete. First impressions ***UPDATE WITH TRACK TIMES***
Old 01-04-2003, 02:46 PM
LOnSLO's Avatar
Default F1 cam install complete. First impressions ***UPDATE WITH TRACK TIMES***
I just finished up the swap over from the TR224 to the Speedtek F1 cam. All I can say is HOLY S@#T!!!!! Feels like I have a 75 shot vs the 224 cam. The 224 would was a great cam, and would pull hard up to about 6200 rpm, then it would start wheezing. The F1 starts making big power when you hit 3000 rpm, up to the rev limiter at 6800. This cam pulls like a mule, and on the first run, I was constantly bouncing off the limiter. As far as drivability is concerned, the F1 seems to be smoother than the 224 at lower rpms, with little valvetrain racket. I just redynoed two nights ago with the TR224, and made a consistent 380-386rwhp. I will be going back this Thursday to redyno with the new cam. Also, there is little to no surging at low speeds with an 850 rpm idle. As others have said about this cam and the X1 cam, as soon as you hit 3000 rpms, it's like hangin on to a rocket. Not much lope to it at idle either, at least not through the SLP dual/dual exhaust. Will update on dyno results next week. Best thing I've done to the car yet! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old 01-04-2003, 02:57 PM
qwik3r's Avatar
Default Re: F1 cam install complete. First impressions ***UPDATE WITH TRACK TIMES***
Im looking for a cam sometime soon, wondering how much that set you back, where you got it from and how much the install was. Also, what other mods do you have? Thanks.
Old 01-04-2003, 03:03 PM
LOnSLO's Avatar
Got it from Speedtek in Dallas for about $430. Did the install myself. Here's my sig
Old 01-04-2003, 04:03 PM
CrankinYankee's Avatar
Sound's like you have a stump puller <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> What valve spring are you using? Make sure you update us with your new number's.
Old 01-04-2003, 04:53 PM
Serial Thriller's Avatar
I didn't see gears in your sig. Doesn't it take a while to hit 6800 rpm with the 3.42s? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
When would you say the 224 started pulling? And don't be afraid to post dyno sheets. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 01-04-2003, 08:50 PM
Louis's Avatar
I agree, THis calls for a back to back graph. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Old 01-04-2003, 09:35 PM
LOnSLO's Avatar
ST - I'm using the 918's for now. This is what Speedtek recommends, plus I spent a while on the phone with Comp, and they seemed confident that the springs would take that kind of lift. But when the LS6 heads get here, I will be going with the 987 duals.
G2 - I'll post the graphs when I get them. I'm expecting a good gain.
Old 01-05-2003, 07:05 AM
LS1derfull's Avatar
Great choice going to LS6 heads, but can you give us any cam specs for f1?
Old 01-05-2003, 07:11 AM
LOnSLO's Avatar
F1 - 230/226 .591/.569 112 +2
Old 01-05-2003, 10:16 AM
ROB'S SS's Avatar
i put in a very simular cam this weekend. its a comp cams 230/228 591/588 111 lsa +4
Old 01-05-2003, 10:34 AM
*Bad Trader*
BYBYC5's Avatar
230/224 .570 .563 111 +0
Hmmmmm... anyone
Know the BTC of theses cams. i have the TR230/224, whould it be worth the effort to change?
Old 01-05-2003, 08:54 PM
LOnSLO's Avatar
BTC <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old 01-06-2003, 10:59 AM
Crowley's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by LOnSLO:
<strong> I just finished up the swap over from the TR224 to the Speedtek F1 cam. All I can say is HOLY S@#T!!!!! Feels like I have a 75 shot vs the 224 cam. The 224 would was a great cam, and would pull hard up to about 6200 rpm, then it would start wheezing. The F1 starts making big power when you hit 3000 rpm, up to the rev limiter at 6800. This cam pulls like a mule, and on the first run, I was constantly bouncing off the limiter. As far as drivability is concerned, the F1 seems to be smoother than the 224 at lower rpms, with little valvetrain racket. I just redynoed two nights ago with the TR224, and made a consistent 380-386rwhp. I will be going back this Thursday to redyno with the new cam. Also, there is little to no surging at low speeds with an 850 rpm idle. As others have said about this cam and the X1 cam, as soon as you hit 3000 rpms, it's like hangin on to a rocket. Not much lope to it at idle either, at least not through the SLP dual/dual exhaust. Will update on dyno results next week. Best thing I've done to the car yet! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm definately interested in your dyno numbers and graph. I'd like to see what power you put out with stock heads.
thanks,
Crowley
Old 01-07-2003, 10:56 AM
bigSS's Avatar
Good post, I like hearing about how cams compare to each other in the REAL world. <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old 01-09-2003, 08:01 PM
Any new dyno #'s <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old 01-09-2003, 08:14 PM
rnr27band1's Avatar
The dyno numbers are on the way, I was there after the car dynoed and its impressive, but thats all I am gonna say.
Old 01-09-2003, 08:44 PM
Boo Yeah's Avatar
LONSLO- can't wait to meet you... when are you coming to get your rear end. I talked to Scott the other day and he said he was almost finished. I think your going to need that POS to put that kinda power down. What are you doing with your old cam????
Old 01-10-2003, 02:09 AM
LOnSLO's Avatar
Well, the results are not quite as good as I had hoped, but I'm happy considering I still have stock heads. Lowest number of three pulls was 395, and the highest was 403rwhp. I'm figuring I gained an honest 15 rwhp with this swap. THe biggest surprise is that the torque also jumped from around 375 to 390 ft-lbs. This was on the same dyno as last week, with identical weather conditions. Now to get some LS6 heads thrown on there and... <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old 01-10-2003, 09:34 AM
ROB'S SS's Avatar
good numbers. i get dyno tuning today and ill post my numbers as well.
Old 01-10-2003, 01:23 PM
bigSS's Avatar
It would be a HUGE help if you could post the dyno graph! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Quick Reply: F1 cam install complete. First impressions ***UPDATE WITH TRACK TIMES***
