PTV clearance in pictures
explain what the piston and valve are doing on a stroke cycle, on the intake stroke the valve is chasing the piston. Heres some pictures to explain PTV.
Here is whats going on at TDC intake stroke, on a large cam, the intake valve is cracked open before top dead center, depending on how early the intake valve opens, valve drop on the heads, radius of the valve, is going to affect PTV. Heres a pic.
piston continues down on the intake stroke
Here is max lift (basically), piston is down in the cylinder, max lift means almost nothing for PTV
Those low lift numbers are the problem, and the faster the cam has the valve coming off the seat the closer your clearance is (in general, of course the duration plays into this as well).
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
What do you mean by a quicker duration? Do you mean a more aggressive ramp rate?
Didn't have sound on computer at work when I posted this
