which cam would you reccomend
Old Jul 29, 2010 | 11:38 PM
SILVER 2288 SS's Avatar
From: boaring place where theres more cows than people
Default which cam would you reccomend
hey guys im thinking of putting a bigger cam in my car i have the ls hot cam in there now im planning on putting a 3200 stall and a set of ported heads and maby a hundred shot whch cam should i or would u reccomend going with
Old Jul 29, 2010 | 11:49 PM
02*C5's Avatar
Ok loaded question is it going to be a DD or a weekend warrior also what type of street mannerism are you looking for. what are your track needs ie what type of et's are you looking for forget about HP specially if your doing an A4. Also if you are going to run a 3200 stall is gonna limit the cam size you can use. 3400 is a lot more forgiving.
I would say this specially with a A4 contact predator Z/ Patric G or Ed Curtis some of the top guys that spec out cams and have one done for you. with Automatics believe it a degree or 2 difference in lobe separation can make the difference between a good cam and a great performing cam for your car.
Good luck
Old Jul 30, 2010 | 12:18 AM
02sslayer's Avatar
ya it really depends, it took vme about a year to decide on the cam i have now. and it took so long cuz i was taking alot into account for my goals.
Old Jul 30, 2010 | 08:25 AM
thats what im trying to do i want good streetability and as for the track im not really as up on it as everyone else is i want a car that drives good on the street and is a monster when i need i to be at the tracl
Old Jul 30, 2010 | 09:43 AM
garygnu's Avatar
EPS cam.check the dyno sections .>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >>>>>>>>>>
Old Jul 30, 2010 | 09:47 AM
TooLateVTEC's Avatar
How much power are you looking to make?
Old Jul 30, 2010 | 10:52 AM
im wanting to try and make about 400 on motor and more on the bottle
Old Jul 30, 2010 | 04:11 PM
TXZ28LS1's Avatar
go with a cam size of the TSP Torquer 2, or the TSP 233/239.
Old Jul 30, 2010 | 06:19 PM
batboy's Avatar
The Torquer v2 would work fine. I have the Thunder Racing 230/236 in my LS1 GTO with a 3200 rpm stall. It's a good nitrous cam and I got into the low 11's with a 100 shot. Going for high 10's once it cools down a bit. I'm currently about 430 hp off the bottle with full bolt-ons and ported 243 heads.
Old Jul 30, 2010 | 07:21 PM
Hows the Cams drivability in ure gto
Old Jul 30, 2010 | 10:15 PM
batboy's Avatar
Pretty decent. Has good torque, 408 ft/lbs @ 4650 rpm. You will need a good tune.
I'll post the dyno vid, towards the end is a clip from back at the tailpipes if you want to know how it sounds. Ignore the filter on the CAI, that was temporary.
http://www.streetfire.net/video/batb...run_742242.htm
Old Jul 30, 2010 | 10:52 PM
ok cool ill check it out
Old Jul 30, 2010 | 10:55 PM
omg i think im in love sounds great
Old Jul 30, 2010 | 10:57 PM
wats ure lsa
Old Jul 31, 2010 | 01:08 PM
batboy's Avatar
112 lsa
Old Jul 31, 2010 | 02:06 PM
i think im sold on that cam
Old Aug 1, 2010 | 12:39 AM
batboy's Avatar
Here's another vid with a short sound clip at the tailpipe. You'll see the camera jerk when I do a little rev, it scared my wife. The vid also contains my dragstrip personal best time.
http://www.streetfire.net/video/batb...109_720881.htm
