Best heads for ASA cam?
Old Aug 4, 2010 | 06:28 PM
madhatter's Avatar
Default Best heads for ASA cam?
A friend of mine is looking to put some new heads on his motor. Currently it is a stock LS1, 241 heads, LS6 intake, 1 7/8 Grots, 3" duals. He was told a long time ago to go with LS6 heads, but there are many other options now. The car did 389/370 as it sits with crap 91 octane. Anyone out there with this cam with different heads?
Old Aug 4, 2010 | 06:30 PM
brokenbird's Avatar
a ported set of 243 or 799 would do nice with that cam
Old Aug 4, 2010 | 08:23 PM
180ls1's Avatar
well that cam was made for 243 cast heads but i imagine that any set of aftermarket heads would do the trick. How much you willing to spend?
Old Aug 5, 2010 | 02:39 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
While he has the heads off switch to a non-road racing cam if he wants a set of heads anyway.
Old Aug 5, 2010 | 04:14 AM
brian_rs/ss's Avatar
so why does he have an ASA cam in the first place?
and to answer yourquestion, basically anything better than 241's. 243/799/TEA/PRC/AFR/TFS.....pic one.
Old Aug 5, 2010 | 12:46 PM
OUTLAWZ RACING's Avatar
prc 5.3 with that little chamber and small runners, the port velocity will be riduclus. Had a buddy back in the day swap some 5.3 heads from patriot and gaind 50 hp and 70 tq avarage across the curve. I think total hp 421 through a stalled auto and 3,73
Old Aug 5, 2010 | 12:50 PM
garygnu's Avatar
used 243s $400,prc $1200-1400,Trick flow $1700,AFR$2300.whats his budget?
Old Aug 5, 2010 | 04:53 PM
madhatter's Avatar
The cam was installed in 02. There were not too many cam choices back then. Not looking to change the cam out either. He is happy with the powerband and I will leave it at that.
He would prefer to keep it under $1500 for everything unless truly significant gains could be had with something else. An extra $1000 isn't worth 20hp. It is a daily driven car that hardly sees the track. All out numbers don't mean everything, just a better ***-dyno feel.
By Brett Foote | 2026-06-04 05:00:17
