HP missing with g5x2 cam
Gomer- I want the house, dog and more than half the money, no restraining order will stop me
Again, to add some "technical merit" to the post... Look at the reason everyone wants to go with an X-pipe setup. It is for the scavenging effect of the X-pipe, I'm sure some hollowed out "half assed" gutted coffee can converters will really induce turbulence into the system and defeat the benefits of the X-pipe. This is my last post, goodnight honey
If you think that the problem is in the heads then why did "JFM" only pull 430 with the G5X3, AS Stage 2.75 Heads and an electric water pump. Seems kind of low to me.
Originally posted by JFM in November 2003:
This is my stock bottom end 99 block.Pistons were fly cut by Jay,tuned at Vette Doctors by Carman.The converter would not lock up so all numbers are UNLOCKED.
All belts on.Stock 10 Bolt with 3:42 Gears.
Electric water pump.
Absolute Speed Stage 2.75 heads and LG G5X3 on a 112.
30 pound Injectors.
430 RWHP thru FLP's and full SLP Dual-Dual Exhaust,unlocked.
446 RWHP with Open Headers thru FLP Test Pipes,unlocked.
Not from what I've seen. The less backpressure the better. Now I have seen cases where people ran open headers and lost power due to the Ltrims being thrown off from outside air screwing with the O2 sensors, but other than that...no muffler is going to outperform a cuttout and no cat is going to outperform a straight Y-pipe of equal size. Backpressure being needed is an old fallacy (as far as LS1s go) and it's been proven countless thousands of times.
Assclown, you do understand that a ported TB can be worth 7-8 RWHP on even a bone stock engine don't you?
"I bet this guys goes through the expense of changing to staight pipes and chages his air box, ported tb and headers and picks up 2 hp."
I'll take you up on that bet. Who's going to hold the $$$ and how much can you stand to lose? Thanks for the donation.
30 pound Injectors.
Bergerman maybe you missed the part about it being an unlocked a4, Seems like some stout results there
Gomer. take a look at this https://ls1tech.com/forums/generation-iii-internal-engine/129667-absolute-speed-stage-2-5-3s-dyno-results-through-a4.html
thats the same set of heads that made 452 untuned in another car
I already said, keep us updated on the results with the changes, a ported tb may be worth 5-10 on a f body but not on a y body tb ,I know I just ported mine with a friend who showed me the defference between the two. Let the guy make the changes and see what he gets. Now everyone knows why I devorced your ***. I should have left you at hello
BTW jfms dyno #`s are some of the highest unlocked #`s I have ever seen. You can easily add 10 to 15 hp to them if it was a locked #.
I dont care if you talk **** about absolute speed but atleast have a clue when you try to make a point
30 pound Injectors.
I don't think you will pick up 15rwhp just from getting rid of the gutted cats, but I think you would get a good amount of torque and it is probably worthwhile to do. Some cars just do not make the same power as others no matter what you do.
Regardless, Good luck!
https://ls1tech.com/forums/dynamometer-results-comparisons/118174-obsssd-s-pp-stg-ii-ls6-g5x3-dyno-graph.html
Gutted cats could actually be the same or possibly a bit worse.
ported throttle body will be another 7-10RWHP easily.
Right there he is at 440RWHP Through a vette IRS. That is damn good IMO
Get a good mid section in that exhaust. I ran my 10.73 with the Random Tech CAT x-pipe.
Roger,
You have to ask your self what your time would have been with the LG Pro Long Tubes. We lose NO hp to any header on the top end, but we pic up plenty of torque at the lower rpms. This low end torque is what will help your car, in the first 330'. ( even your a A4 with the high stall). A 6 speed car would benefit even more in the 330' with more low end torque.
The high stall A4 is the only thing that saves the shorter headers. I understand that you have what you have, and you probably don't want to change, but that doesn't mean that you are not losing low end hp. And your package may not be hurt that much by losing the low end torque.
Our headers are what they are. They make more low end, and that is a fact. If you don't think that it would help your package, then that is ok, but just knowing that there are cars that go fast without some particular mod, doesn't "Negate" the value of a particular mod.
Thanks
Lou G
I love the cam's, I love the cars he builds, and I love hive willingness to always help people out if they need questions answered.
Sorry for the randomness, But i aprecciate people who like to pioneer and make big, loud and reliable HP
I Wouldnt Change The Tpis Headers
My Car With Tpis Put Up 480 Rwhp On The Dyno
And Traps 130 Mph@10.58 !!!! What 346 Runs That???
I Would Go With An Off Road X Pipe And Ported Tb
I Do Also Reccomend The Vara-ram As Well
And Get It Re-tuned By A Ls1-edit Expert
I AGREE with BRENT's aforementioned statement 100%!!!
Good luck on your car..
That was one fast SOB..
Dynos are good indicators but not the end all. IMO
