HP missing with g5x2 cam
You have to ask your self what your time would have been with the LG Pro Long Tubes. We lose NO hp to any header on the top end, but we pic up plenty of torque at the lower rpms. This low end torque is what will help your car, in the first 330'. ( even your a A4 with the high stall). A 6 speed car would benefit even more in the 330' with more low end torque.
The high stall A4 is the only thing that saves the shorter headers. I understand that you have what you have, and you probably don't want to change, but that doesn't mean that you are not losing low end hp. And your package may not be hurt that much by losing the low end torque.
Our headers are what they are. They make more low end, and that is a fact. If you don't think that it would help your package, then that is ok, but just knowing that there are cars that go fast without some particular mod, doesn't "Negate" the value of a particular mod.
Thanks
Lou G
Think you will find cylinders at 10% or more cause of the valve seat problem with PP heads.
Pulled a set off a car this past week.Motor had 2 hours of run time and EVERY cylinder had +10% leakdown with a gapless ring.Turned out to be the valves leaking badly on random cylinders.
Just a hint for ya.
What did they update on the heads to fix the oil consumption, cause i went through a lot of oil in the first 1000 miles i guzzled 2 quarts
