Is this valvetrain noise?
Old Aug 15, 2010 | 11:21 PM
89L98T56's Avatar
Default Is this valvetrain noise?
I can't tell and the squeaking throws me off.
http://www.youtube.com/watch?v=NQNW94OUFTc
It's got good oil pressure.
I have a Vengeance racing vindicator cam (.605 .596 240/244), LS7's, 7.325" PR's, stock rocker arms, AFR 205's milled to 62ccs.
I never measured for lifter preload just went by what someone told me to get.
I can also push some of the lifters down by hand and the rest are solid. All parts have less than 5k miles.
Thanks
Old Aug 15, 2010 | 11:32 PM
01wssick's Avatar
could be bent pushrod, lifter, broken valvespring, rocker arm not tight, not right length pushrod. start taking apart and find out..
Old Aug 15, 2010 | 11:36 PM
89L98T56's Avatar
I have checked all of the above besides pushrod length.
And half of my lifters are easily compressed by hand. Is that normal?
Old Aug 15, 2010 | 11:48 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
This. Probably what you are hearing. Not to mention that cam isn't going to sound like butter on the valvetrain. I ran a 244/248 with a 7.350. I know what you are hearing.
Old Aug 15, 2010 | 11:52 PM
89L98T56's Avatar
And the squeaking???
Old Aug 15, 2010 | 11:59 PM
01wssick's Avatar
I also have a t-rex cam 242/248 heads 59cc and only running 7.350 pushrods too. Get a pushrod length checker and measure.
Old Aug 16, 2010 | 12:04 AM
89L98T56's Avatar
What does yours sound like?
Old Aug 16, 2010 | 12:05 AM
StealthFormula's Avatar
Definitely sounds like a loose rocker arm to me. While your at it go ahead and check the pushrod length to see if the geometry is correct because that is never a bad idea. Comp makes a nice length checker IIRC it is part# 7702-1 in Summit.
Old Aug 16, 2010 | 12:14 AM
89L98T56's Avatar
Thanks for the help. And I double checked all the rocker arms and they were good.
Old Aug 16, 2010 | 12:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Maybe one of the trunions is about to come undone?
Old Aug 16, 2010 | 01:24 AM
flintwrench69's Avatar
Thanks
Thats never a good idea. You have to measure for it. I just went through this a few days ago after installing some TFS215s. They came with 7.5 pushrods but I had them milled .010 & new LS7 lifters. After following YTs instructions installing their rockers I tightened the rocker bolts with a socket finget tight with slight tension on the pushrod, then counted how many turns it took to get to 25 ft lbs(or 22 ft lbs for stock rockers) & it only took 1/4 turn, which is about .012 preload. Do this on the cylinder thats on TDC compression stroke. Should take about 1 to 1 1/2 full turns from finger tight to torque for decent lifter preload. Thats not enough preload & I knew if I put it together with the 7.5s it was gonna be noisy. I pretty much knew from doing that I was gonna need 7.550s & using the adjustable pushrod tool. With the 7.550 rods it took 1 full turn to torque & its not noisy.
Old Aug 17, 2010 | 01:34 AM
eduardo's Avatar
hey I have the same noise and everything checks out fine. I bought a cam package from TR and they told me to get 7.425 push rods. Is this the right push rod length for a raptor cam, and new ls7 lifters. I always that since the new ls7 lifter are taller then stalk ls1 lifters that the push rods should be shorter. I too need help, dont want to start a whole new thread since we are on topic with this one. I hate the noise, so if I can make it any quieter I will. Thanks.
Old Aug 17, 2010 | 01:37 AM
eduardo's Avatar
Again I do have double valve springs, I've read that this and the fast ramp rate of the cam will give me a NOT so quiet valve train. I want to get my car tuned already, don't want to take it apart again.
Old Aug 17, 2010 | 08:13 AM
Thats what a lot of people do on here, me being one of them when I installed my cam last spring. I did what most suggested, get 7.400 pushrods. Thats with the stock lifters & PRC dual springs. I did hear a lil ticking noise on occasion but it ran good. I am sure I couldve used a lil longer pushrod but I never measured for it. So I probably didnt have quite enough preload on the lifters. Thats one of the reasons when I installed the heads that I measured for it & got the right length pushrods. I didnt want to have any valvetrain noise & I dont now.
Not true from what I have been hearing. LS7s like more preload. Read my previous post above & or do a search.
Old Aug 17, 2010 | 08:24 AM
KevinR's Avatar
7.425 is the right pushrod for the RapTR cam.
Old Aug 17, 2010 | 09:25 AM
eduardo's Avatar
Well after 25 miles into break in surprisingly my car started up on the first try this morning, and to my amaze my valvetrai. Got quieter but I can still hear it just not as bad. Maybe it just needs more break in time.
Old Aug 17, 2010 | 09:28 AM
eduardo's Avatar
KevinR do you have a video of your car runnng on YouTube . I'd like to compare mines to yours.
Old Aug 17, 2010 | 09:38 AM
KevinR's Avatar
No I don't. I can try to post one up later this week.
Old Aug 18, 2010 | 12:23 AM
89L98T56's Avatar
I wonder how much preload my lifters were getting with the LS7's and a 7.325" PR?? Could a lack of preload cause a lifter to fail? Or could the lack in preload cause such a racket?
