Got $2000 need better ET
Current setup:
Stock LS1,
4L60E transmission
3.73 gears
auburn gear differential
WS6 clone suspension
SLP lid
Exhaust cutout with high flow cats
160 deg thermostat
other free mods
nitto drag radials (getting new tires next year, not a fan)
thanks for the help !
Current setup:
Stock LS1,
4L60E transmission
3.73 gears
SLP lid
160 deg thermostat
other free mods
after that, save up about another 1000 to 1500 and go cam only. easy 11s on some tires that hook
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Edit: forgot to stress a trans cooler with the converter otherwise you'll need a $2000 built tranny fairly quickly. Also stay away from a FAST 90-92-ect intake. For stock cubes the LS6 intake manifold is more than enough and doesn't cost half your budget like the FAST.
I would not drop a FAST unless everything else is done. There are better/cheaper gains to get with your setup first!
Wrong...
