Finally Dyno'd my 10 second cam only setup
Old Jan 23, 2004 | 03:56 PM
Mike Hoffpauir's Avatar
Default Finally Dyno'd my 10 second cam only setup
I finally got to dyno my car This is the same setup I've had since april of 2002 and went a 10.98 with, except I sold the carbon fibre drive shaft and reinstalled the factory aluminum piece. I also am on factory 16 inch wheels now.
My setup includes a Futral FM4 226/226 575/575 114 cam, Yank tp4400, 4.10's, ls6 intake, etc, etc. I am still using my 1st set of comp 26918's from april 2002.
We dyno'd both locked and unlocked. Needless to say I am very happy
Attached Thumbnails Finally Dyno'd my 10 second cam only setup-mike-h-dyno2.jpg   Finally Dyno'd my 10 second cam only setup-mike-h.jpg
Old Jan 23, 2004 | 03:57 PM
Sorry about the quality of the graphs. It seems the software I used to resize the graphs does so at the expense of legibility.
Old Jan 23, 2004 | 03:58 PM
30th t/a's Avatar
its very hard to read.
Old Jan 23, 2004 | 04:11 PM
Vents's Avatar
but still VERY cool ;D
pimp Mike, very pimp. thats what ya call puttin power to the ground.
Old Jan 23, 2004 | 05:04 PM
gomer's Avatar
That's pretty damn impressive!! Way to go man.
Old Jan 23, 2004 | 05:38 PM
Revelation222's Avatar
Bout damn time Ive been waiting for someone to get some dyno time for this cam by itself in an A4. Those are great numbers. Congrats. How would the cam be for a daily driver? Ive got a VIG 2800 now, do you think I would need a larger stall with the 226?
Thanks and Congrats Again
Old Jan 23, 2004 | 06:08 PM
SloppyRob's Avatar
Im definitely going with that cam.
Old Jan 23, 2004 | 06:13 PM
Damian's Avatar
LSX Mechanic
FMS
Old Jan 23, 2004 | 06:28 PM
PHIL H's Avatar
His latest cams offer alot of choices too.. I am getting one!!
Old Jan 23, 2004 | 06:32 PM
Damian's Avatar
LSX Mechanic
You can't go wrong w/ FMS. Alan is a RACER. He does not play dyno wars. He win's races, and builds fast cars. If you want a FAST car, call Alan....PERIOD...
josh
Old Jan 23, 2004 | 06:43 PM
383ss's Avatar
DAMN Impressive!!!!!! looks like a pretty broad powerband
Old Jan 23, 2004 | 06:47 PM
Gary Z's Avatar
Please pardon my ignorance but does "cam only" imply stock exhaust manifolds?
Old Jan 23, 2004 | 06:49 PM
Damian's Avatar
LSX Mechanic
Cam only implies that the cylinder heads are completely stock. Instead of a "Heads/Cam" setup, it's "Cam only"....
Old Jan 23, 2004 | 06:52 PM
VINCE's Avatar
Shorty Director
Nice!!!!!
Old Jan 23, 2004 | 07:53 PM
StreetStalkerZ's Avatar
Those are some good numbers mike I guess i need to go dyno my setup just for fun now. Oh! i got all the stuff done on the car and i should have the FTRA on the car for my next track visit so i might be close to joining you ET wise
Old Jan 23, 2004 | 08:17 PM
foff667's Avatar
LS1TECH Sponsor
its such usable powerband too...6000rpm peak hp...might even give you some spring/drivetrain longevity others wouldnt be able too...NICE
Old Jan 23, 2004 | 08:26 PM
Kent1's Avatar
Very nice power across the curve and lots of horsepower. Your car was one of the first to be the fastest and you did an outstanding job to set the example for others. Keep up the good work. Thanks for the sharing the information and cam was definitely a good one. Cheers...............
Old Jan 24, 2004 | 08:47 AM
This cam is an excellent daily driver cam. That's why I have it, and not some 230+ cam. The idle is fairly mild through a closed exhaust system, but with an open system you can hear the cam hit. Surging and stalling are not a problem with the fms tuning.
The cam will work fine with any stall. But it will produce better times with the tp4400 because of the shift extension as well as the better ET producing torque converter. The same could be said for any cam out there from stock to 230+.
Old Jan 24, 2004 | 11:07 AM
Mike,looking at your dyno curve it looks like the 918s are doing very good with that cam.
Do you have any plans for the car or are you going to set back and wait for me to catch up to you On your 11.0s-10.98 run was you on the rev limiter at the 1/4 with the 4.10s? Last time i went if i held the gas say 20-30 feet past the 1/4 i would tap the rev limiter and i was curious if the 4.10s maxed out around 121 on the 26x10 ET Drags. If i have problems next time with this then im going to have to switch back to 3.73s.
Old Jan 24, 2004 | 01:26 PM
Hardtop's Avatar
Very nice Mike. That is exactly the cam I've been thinking about changing to, unless Josh wants to PM me the specs to something else.
Bruce
