Donkey Dickin it
Old Aug 19, 2010 | 07:21 PM
intenseblue's Avatar
Default Donkey Dickin it
Anyone tried a cam like this? 238/240 111LSA 4 Degrees advance. Intended for an 11.5:1 compression LS2 in an Fbody.
The IVC is 46 degrees. Overlap if I calculated right would be 17 degrees.
This is the build
LS2 6.0
Callies crank/rods
Wiseco -3.2cc pistons
TEA Stage 2 LS6 heads with 62cc chambers
Cometic .040s
Full Comp valvetrain: timing chain, roller rockers, lifters, 921s with titanium retainers
LS6 intake with TPIS 90mm conversion, Cartek ported with NW TB
FTRA, FT Lid, 85mm MAF
Kooks 1 7/8" headers, custom 3" True duals with Magnaflow X and Mufflers
MN12 Trans
Moser 12 bolt 3.73 gearing
Textrailia clutch, steel flywheel
I want to know if a cam this size will be a dog on bottom. I believe the DCR is gonna be around 8.7
Thoughts/opinions? I've been contemplating what cam I'm gonna go with for a little while. Seeing as how they're all the same price I figured might as well get the most out of it. Had been thinking about a 230/232 on a 111lsa, I just dont wanna kick myself for leaving power on the table at no extra cost.
Old Aug 19, 2010 | 09:23 PM
09camaro383's Avatar
I think you will good to go with that cam is also similar to the ms4 cam (239/242 .649"/.609" 111) im very happy with the results
