cam walk?
Old Aug 17, 2010 | 02:54 PM
383camaroz28's Avatar
Default cam walk?
Whats the best way besides draining the system an pullin timing cover? I heeard if i pull my intake off an valley cover. i can check it that way?
Reason being my tach doesnt work an worked fine before install. An i changed cmp an looked at the wires to it.
Thanks
Old Aug 17, 2010 | 03:30 PM
Pocket's Avatar
Cam walk wont affect the tach signal, besides it has nowhere to go unless you forgot some parts. Bearings keep it on the proper axis of rotation. Retainer plate keeps it from moving forward, timing gear keeps it from moving rearwards
When you did the cam swap, is it possible you knocked the crank sensor when locking the flywheel when removing/installing the balancer bolt?
Old Aug 17, 2010 | 04:07 PM
Everyone says crank sensor wouldnt effect the tach not working.
I puled my motor out for the swap. Put all new gaskets an arp bolts.
I put arp cam plate bolts on with arp lube not locktite. I didnt pull my motor out with cyl 1 tdc. Some people say a crank relearn is needed others say no
But i read somewhere on here from 04 of a guy that had same prob, an hia cam bolts backed out moving 1/4 inch an didnt make tach work
Old Aug 17, 2010 | 06:52 PM
Pocket's Avatar
If the cam sprocket bolts backed out that far, they'd dig into the timing cover
The crank sensor controls the tach, I dont know how else to put it. Cam sensor's only function is to let the PCM know which stroke the engine is on. After start-up it is not used again
Old Aug 17, 2010 | 08:20 PM
Alright pocket i tryed everything else but that i hope ur right lol,
I did have the crank sensor out while i was painting my block an bay
Old Aug 17, 2010 | 08:28 PM
SOMbitch's Avatar
Someone correct if I am wrong but I thought the tach got it's reading from the cam position sensor.....
Old Aug 17, 2010 | 10:32 PM
Pocket's Avatar
Fire up your TA and unplug the cam sensor. Find out for yourself
Old Aug 18, 2010 | 12:25 AM
The_Rizzle's Avatar
crank does spark, cam does individual injector/spark timing. Most all sequential EFI engines do this. Batch/bank fire efi's don't use cam sensors. However, with the computer controlling 8 coils, the cam sensor must be needed, just like injector control. Your tach signal will come from your crank sensor.
Old Aug 19, 2010 | 08:45 AM
I got my sensor lastnite im gonna put it in soon, hope it fixes it
Old Aug 19, 2010 | 10:13 AM
Taspeed's Avatar
Cam sensor behind the intake controls the tach. Make sure it isn't broken or unplugged. My sensor went out and i had to get a new one few years back. Thats all it is. Nothing to do with cam walk, or crank sensors.
Old Aug 19, 2010 | 11:21 AM
Idk wat else it can be, i didnt put it in yet tho
I checked all my grounds, there a way to test the connector?
Old Aug 19, 2010 | 12:21 PM
SOMbitch's Avatar
Read this>>>>>https://ls1tech.com/forums/generatio...enor-code.html
Old Aug 19, 2010 | 12:30 PM
Taspeed's Avatar
not the crank sensor
if the crank sensor is bad the car will not run. It controls timing for the pcm.
Old Aug 19, 2010 | 01:49 PM
How can i check power to sensor?
Old Aug 19, 2010 | 02:14 PM
1SLwLS1's Avatar
Definitely not Crankshaft Position Sensor, you would not get any spark.
This is a general test procedure, use at your OWN risk! Pin 1 should be 5V, Pin 2 should be ground, and Pin 3 is your signal. With the engine cranking/spinning, Pin 3 should be between 0-5V.
Old Aug 19, 2010 | 02:29 PM
Is there a way to check with efilive?
Old Aug 19, 2010 | 02:33 PM
1SLwLS1's Avatar
I would think so, not sure though as I have no experience with EFILive or HPTuners.
Old Aug 19, 2010 | 02:52 PM
So i guess ill return crank sensor
When i start the car the speedo an tach makes a sweep then back down n tach goes to 0, someone told me it needs a crank relearn
Old Aug 19, 2010 | 09:23 PM
Ok so i dont got p0342 anymore, i hooked up efi scantool n scaned it an now its throwing p1367
