383 question
I am looking to install this engine in my 944, the ls1 already was running but found out I had a bad set of pistons and bad block.
I have a set of rebuilt ls6 heads with dual springs and want the engine to be smooth and have a good highway power to fuel the speed the car can make.
any advice, I figure the idle is related to the cam, so I just want to know the facts if its possible to have a smooth running 383 and not a rough loping engine.
One other question, What is the top end rpm that a 383 stroker can hit? I dont want to drop below 6500.
This is all inside my 86 944 turbo/951 porsche. So that will be about the limit of the transaxle as far a torque goes. It will be sick once I get it together
It'll be fun for sure
Just don't break that transaxle. You can buy a 4th gen F-body for the cost of that thing
I am new to engine building so this is my first engine and I just want to make sure i do it right.
I know true sports cars displace rotating mass by smaller ci with more pistons. I really want a smooth idling highway monster. I hope to rev out to 7k or just above. Is the rotating mass of a 383 stroker offset so much that this can not be done?
also I was under the impression if I went this route I can get a cam that would move my torque curve up to 2-3k and all for more power top end.
I look at the CI and see that bigger is not always better but it brings more power possibility to the engine.
what do I need for a smooth idling drive able, highway car that can spin to 7k and not have issues?
Diving further into getting forged and balanced stock sized internals, is it possible and what would be needed to spin the rpm to 7k redline, with a power band up to 6500-7000 area.
I already have ls6 heads with dual comp springs, that seat at 150 or so. their
#26921 comp cams.
I dont have any other upgraded parts anywhere else.
#26921 comp cams.
