Is it tough to assemble a motor...
If an engine has had all the correct machine work, then it is like putting legos together. You do need some basics like feeler gauges, a torque wrench, a ring compressor, etc... The only things to really check are bearing clearances with plasti gauge (that strip stuff...can't remember if thats what its called now....
I personally don't ever see having a shop BUILD a motor for me.
Having never built a motor, you’re asking for problems. Just save up and have someone that knows what their doing assembly at least the bottom end.
It is really not that difficult but is it worth buying a bunch of tools and spending all that time and money on something that you could f up. (Personally I prefer to have someone else to blame) If you do decide to do it yourself, buy a few books and read up, double check everything and most importantly do not rush, it can be done. Either way, hope it turns out.
Im not talking about any sponsors here, just shops local to me.
Prices were anywhere from $800-1200
screw that
I'd be curious to see an actual breakdown of where the cash goes.
Hey, if the block and head are used then you need to get it line bored (new bearing size), decked, and the heads need a light cut on them. You should also have the cam bearings checked.
OH.....and a Big Me Too on what Cannibal (Levi) said.
joel
screw that
Also as Cannibal said how much does it cost to buy the needed hand tools, it is not outrageous but isn't cheap either.
Now i am not saying not to do it yourself as it is not all that difficult, you just need to know what you are doing and take your time and check everything twice.
he has a good point......if you are asking how much the tools are, then its a pretty good bet that you don't have the exsperience to build an engine right now.
Have a local shop THAT YOU TRUST (talk to a number of shops before you decide on one) build it and go WATCH them. Any good shop will let you watch the assembly of YOUR motor (I would be werry of one that didn't want me around...a kind of "what do you guys have to hide?"
) and ask quetions. Thats how you learn.
