Money no object... Best rocker arm out there...
I like the OEM rocker with the trunion upgrade for most applications. I did however, succumb to a set of Jesels when I got some Trick Flow heads awhile back - and I am now afraid I'll never go back to anything else.
With the caveat being we are discussing a hydraulic roller application Im all about the Yella Terra Ultralites....I don't care if I have to replace a broken one down the road or not. Lightweight is what you want (and need) in a hyd set-up that you plan on buzzing.
I just built another engine which I opted to use them on and I have helped numerous customers with them. They had an issue a awhile back they corrected and the bottom line is there are alot of these rockers out in the field that haven't failed.
If we are discussing a solid roller its an altogether different story....
I'm assuming the OP is inquiring about a hydraulic application.
Speak to ten guys and you will get a half dozen different opinions but I like the YT's alot
Cheers,
Tony
Cheers,
Tony
Cheers,
Tony
Cheers,
Tony
I DO care if one or two breaks down the road, I drive my car, alot. Getting towed home, maybe having aluminum pieces fall into my engine, having multiple days worth of downtime while waiting for parts to be mailed from AU.
Sorry. That really isnt an option in my book.
I value your opinion greatly.. Not to bash it.. But MTBF is not really something I want to play with.
The jesels are pretty light?
Regarding the YT's, Im comfortable the reliability of the newer rockers are much better. They addressed a problem with a batch of rockers that shipped a looong time ago and IMO their customer service handling the situation was impressive.
A Jesel or a T&D would be of course be ultra reliable.....will it work as well at high RPM in a hyd roller application, probably not IMO. A stock rocker with the upgrade bearing would be reliable....and it would rev pretty well (they are light), but its going to cost you some valve guide life from the huge scrub pattern on the tip of the valve (its a square....not a rectangle).
Honestly, I don't see the perfect solution for you unfortunately no matter how much money your willing to spend.....but only you can decide which hook you want to hang your hat on and which compromise of the numerous choices you have looks the best.
-Tony
IMO, the Jesels were still designed around the premise a solid roller would be used....I dont think they are as light as the YT's.
-Tony
-Tony
Jesel makes a a non adjustable setup for use with a hyd roller.
#32
#34
#35
It is an issue that comes up decently often using those rockers in an application such as his.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
#36
Thoughts:
Properly designed and setup LS hydralic roller valvetrains with stock LS lifters, stock LS rocker arms, stock weight valves and the correct lobes, springs, retainers and pushrods can and do run 7900-8000 drag racing with no maintenance over many months/years? of racing. Believe it or don't orangeapeel.
As far as rocker requirements for higher revving (or any rocker for that matter) I'd say stiffness, low mass over the valve (low rotational Moment of Inertia) and low overall mass are important in that order. Roller tip rockers, even "ultralites" or Jesels have more mass (weight) over the valve than stock LS rockers. I have not yet seen an aluminum rocker arm assembly that was as stiff as a stock LS.
I, personally, would not want a valvetrain where I had to accept the "occasional" rocker arm failure.
Originally Posted by Darkman
Just for the record "Yall" is the singular form of the plural "All Yall."
Regards,
Jon
"Who do you trust?" ...Joker (Batman movie)
#39
#40
