LQ9 purchased...what mods to do
Old 08-25-2010, 07:35 PM
colorado808's Avatar
Default LQ9 purchased...what mods to do
As the title says I've purchased a LQ9 complete. Current plans are to change cam/head/intake. Any suggestions on combo's? Cam in in debate and probably will go with a fast intake but the heads is unsure.
L92 vs 243? Pros and cons, cost difference or should I have my 317 milled?
Has anyone had any clearance issues with the fast lsxrt? I'm sure I missed a few but feel free the mention anything.
Thanks
Old 08-25-2010, 07:53 PM
09camaro383's Avatar
go with the l92 heads, a fast intake, a custom cam and 1 7/8 headers you will be in the 450rwhp or more
Old 08-25-2010, 10:13 PM
would patriots l92 head be good. I haven't searched for any reviews on them yet but I will. Or stock would be good.
Old 08-25-2010, 10:19 PM
Read this!!
http://www.gmperformanceparts.com/_r...der%20Head.pdf
Old 08-26-2010, 12:36 AM
What intake would fit on the L92 heads?
Old 08-26-2010, 01:04 AM
180ls1's Avatar
what are your goals in terms of driveability, power and how much do you have to spend?
Old 08-26-2010, 02:10 AM
It will a daily driver for the most part. Looking to reach 400-450 hp range. I'm actually looking to get a fast but not sure yet.
Old 08-26-2010, 03:11 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You can find the 90's for freakin' cheap thanks to the 92's and 102's. Sometimes you can find a 92 for cheap just because someone wants the 102mm like yesterday. Just keep your eyes peeled.
Old 08-26-2010, 03:22 AM
FBodyPerformer's Avatar
Originally Posted by 09camaro383
That's a great read! Thanks for the link. Reading stuff like that makes me upset that I still have an ol' stock cube LS1 lol
Old 08-26-2010, 04:49 AM
So the 90 will bolt on to the l92 head? I didn't think they could. Also would a ls2 or ls6 intake bolt to it and which would be better?
Old 08-26-2010, 07:15 AM
oops I meant ls3 vs ls6. would the ls6 bold to a l92 head?
Old 08-26-2010, 09:21 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
No the LS6 Intake will not bolt on to the L92 head because they have different shaped intake ports.
The L92 heads are a great setup but one thing you want to keep in mind is that its hard to get good compression in the motor with them. They have a large chamber like the stock heads do so it takes a lot of milling to get them down to a good chamber size. You also want to keep piston to valve clearance in mind as those heads have a pretty large intake valve. I would recommend exploring the 243 heads a little. They start with a smaller chamber, which makes it much easier to get compression back in the motor. If you are going to be daily driving the car you are going to want good compression, without it the motor will seem like a slug down low.
Old 08-26-2010, 04:53 PM
Thanks for the info and will do on researching the 243's. I just heard/read that the l92's flow better than 243's but didn't know there might be clearance issues.
Old 08-26-2010, 05:16 PM
Are all 243 casting the same? Whether they came off a 5.3 or 5.7 etc?
Old 08-26-2010, 05:44 PM
Will a ls3 intake work on 243's? I know they fit on l92's but not sureo n 243's?
Old 08-26-2010, 11:41 PM
The Lq9 has a 4.000-inch bore and the L92 heads will bolt right in with no problem!! the only bad thing like JohnJanz said will be that they have larger combustion chamber 68 or 70 the 243's have 64.5 or so. Ls3 intake 243 heads NO, Ls3 intake L92 heads YES,
Old 08-27-2010, 12:05 AM
MASS seller approved
smok'nZ's Avatar
i would get a set of stock L92 heads 350 ea scoggin dickey and get a custom cam from pat g people have seen 500+rwhp with cam only LQ9/LS2 with stock L92 heads
Old 08-27-2010, 12:51 AM
Thanks...just to verify the part #12615355 for the l92 head. Is that $350 assembled or bare? As far as the cam, aside from the custom grind, would any other cams out there work i.e. comp cams, tsp, etc?
Old 08-27-2010, 01:09 AM
Squirts11's Avatar
Originally Posted by smok'nZ
i would get a set of stock L92 heads 350 ea scoggin dickey and get a custom cam.
x2. No doubt. ls3/L76 intake too.
Old 08-27-2010, 02:09 AM
GR8GAME's Avatar
Stroke to 408, forged rotating assembly, l92 heads, dished pistons, D1SC Procharger or similar...
Quick Reply: LQ9 purchased...what mods to do
