ls3 cam in an ls1
Old Aug 27, 2010 | 03:47 PM
george g's Avatar
Default ls3 cam in an ls1
Will an ls3 cam work in an ls1?
Old Aug 27, 2010 | 03:51 PM
rtrygstad's Avatar
I don't think so. I think the LS3 cam is a single bolt while the LS1 is 3 bolts. I'm not positive though.
Old Aug 27, 2010 | 06:08 PM
george g's Avatar
Yeah,I know about the bolts,but didn't know if you could use the ls3 cam gear with the ls1.
Old Aug 29, 2010 | 09:02 PM
joecar's Avatar
You need a cam sprocket that has the x1 reluctor "tooth" like the pic... I don't know if the 3-hole sprocket fits the 1-hole cam, can probably be made to fit... this sprocket is what GM gave me when I asked for an LS1 cam sprocket... I assume the dowel hole is in the same position as the LS3 cam.
Also need the front timing cover that accepts a cam position sensor.
Also need a cam sensor extension harness to reach the timing cover.
Old Aug 29, 2010 | 09:16 PM
DVS99TRANS's Avatar
Like Joecar said above^^^
The other thing is that the intake/exhaust splits on the LS3 cams won't be optimal for a LS1 car. The LS3 cams are made with the purpose of very high flowing LS3/L92 heads on the intake side, let alone the exhaust portion. It could be done but isn't worth the effort without adding LS3/L92 heads in my opinion. You'll make more power of course but with all that trouble you could just add a LS1 spec'd cam for better efficiency.
Mike
Old Aug 29, 2010 | 10:50 PM
SSmoken's Avatar
not worth the time and effort. go with something you'll enjoy alot more.
Old Aug 30, 2010 | 02:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you REAALLLLYY wanted that cam, you could always have a custom cam ground with those specs.
Old Sep 17, 2010 | 06:31 AM
fastazzls1's Avatar
also if not mistaken dnt ls3s have VVT and an phaser on camshaft i know l92 have this
Old Sep 17, 2010 | 08:01 AM
abi's Avatar
abi
No! LS3 does not have VVT or DOD. 1X cam positioner has been deleted from the cam core as stated. Its a pretty lazy profile, better to choose something else even if you did trip over one in the street.
Old Sep 17, 2010 | 08:32 AM
fastazzls1's Avatar
ok thanks couldnt remeber lol i am a modular guy but take an interest in all makes and models
Old Sep 18, 2010 | 11:27 PM
tonytone4143's Avatar
Mike
+ 1 on this
Old Sep 19, 2010 | 05:15 PM
Squirts11's Avatar
Mike
Originally Posted by tonytone4143
+ 1 on this
I disagree. Not towards the LS3 cam specifically, but towards the "theory" above.
While big splits between the intake/exhaust durations haven't been common practice in recent years, newer technology has shown this isn't the case. Many assume such spec's are only geared towards nitrous cams, but manipulation of the valve events is more more indicative of the ENTIRE powerbands' performance than simply the advertised durations @ .050".
Hell, most of Geoff's (co-founder of Thunder Racing) EPS cams have 8-12 degree splits (even for stock-headed LS1's), and many are starting to notice why cams with small(er) intake lobes and generous duration splits are outperforming larger cams.
