lingenfelter gt1 gt1-1 cams
just wondering if anyone is running them, i wanna see or hear dyno results nvr seen them.. have seen a youtube video of a trans am saposbly running a gt1 cam but it sounds insane.. and the cam spec dont even show alot of duration so im sceptical.. anyways.. let me know what youve heard.. thanks!
i have been running my lingenfelter gt1-1 for over a year and a half and it is an awesome cam with a pretty radical idle. i made 473 hp and 434 ft/lb on the dyno. my mods are patriot stage two ls6 heads 59cc chamboer with 2.055 int. and 1.575 ex. valves. also run full underive pulleys 1 3/4 slp headers, through an offroad slp y into 3 inch straight exhaust. also have yella terra 1.7 rockers, fast 92/92 ported, and a tnt f-2 nitrous setup. these numbers were made on motor only no spray and i could not be happier. ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
the specs on the cam are 229/242 duration and .631 lift on both int. and ex. sides with a 114.5 intake centerline. yea i think it is definately a cam that should be discussed more and i have the numbers to prove it lol
i would also like to add that i did not have to fly cut my pistons like lingenfelter suggested but i will say that my ptv is very close lol. also i rev this cam to 7200 rpm all the time and have never had an issue.
on my old setup with a 224 228 cam with .598 int .603 ex with 112 lsa i only dynoed at 434 and 398 with the same heads and intake and all the only changes i made when i put in the gt1-1 is i ported my fast 92 myself and added yella terra ultralite rockers other than that all mods were exactly the same. so say i gained 8-10 hp with the rockers and 8-12 by porting the fast roughly, i still gained anywhere from 20-30 rwhp over my old cam. the cam is very streetable it only has 6* of overlap but the idle is super nasty. tune plays in as one of the biggest factors in streetability but overall imho this cam is awesome. LINGENFELTER all the way. hot rod mag did an article on this specific cam a few years back so you should be able to google it and find it... they picked up over 100 bhp on a 5.3 with just this cam swap and headers
