Cam that doesn't NEED a tune?
it's rich and idles rougher than a stock cam should...if a stock ls1 cam acts the way his does I wouldn't try to run anything else
but you should be more worried about a stall first anyway...
j/k man, but most of the guys are right, about the only cams you wouldn't really need a tune for are so small that they honestly are not worth the effort, and most ls1 tuners will only charge that much for a one time fee, then just charge for their time after that. If you want the number of the guy that tuned my red car I can send it to ya, he stays in Baytown and does street tunes, so you won't have dyno numbers but you will put up numbers at the track, which is I am sure what you are more interested in, let me know man!
However, you "can" run an LS6 cam in an LS1 with no other tuning and pick up 10-15rwhp with zero ill effects on driveability.
