Tapping Sound from Passenger Side Head?
Also, I had a D-1SC on the car for a minute before going to the turbo. When the guy who installed the turbo was trying to put the stock crank pulley back on, he said it wouldn't fit because it was hitting the double roller timing chain cover???? It had fit on with no problem before so I don't know what that was all about. He had it machined down to clear and then ran an all-thread and a nut to hold it on. He assured me that he had built several motors with over 800 hp and ran the crank like that before in some of them with zero issues. I came across a thread today where a guy was having my exact same issue after installing a new crank pulley. Can an improperly installed crank pulley have an effect on the oil pump or somehow cause oil pressure problems in the crank?
My fresh build broke on the dyno making a very similar noise....it was a broken ring land on #7.
