Tapping Sound from Passenger Side Head?
oil through the intake side. I haven't determined if they are not getting scavenged properly or if they (or just one) are bad and need to be rebuilt. Either way, they (or something else) is causing oiling and cooling issues with the motor. Even after checking the thermo and having the cooling system flushed and vacuumed, it still gets up a little over 210 degrees after being driven for a bit and warming up and stays there. Around the same time that starts to occur, the oil pressure begins to drop and it sits at about 5 psi or so at idle. It is at this time only when this tapping sound begins. It's coming from the top passenger side of the motor somewhere. At first I thought it might be the alternator or relocation bracket or the water pump, but it really sounds like it's coming from somewhere inside the head itself. If the car is turned off for a good while and allowed to cool off, the sound goes away and everything seems normal. When it gets warmed up again, all these same old symptoms come back. The oil was just changed and the level still looks good on that as well so I'm at a loss as to what to do now. I need to know if this is a sign that some potentially serious, permanent damage has been done to the motor, or if it's just and oil starvation or overheating issue that will go away when the source of the problem is discovered and fixed. Here is a video I took to try and give you all a good idea of what it sounds like and where it sounds like it's coming from:
http://www.youtube.com/watch?v=KKUtS...e_gdata_player
Chris
