Shaved heads and valves wont shut
The motor has shaved LS1 heads on it and should be 200psi+. The motor doesnt smoke at all and the plugs look good, not black at all so I figure the rings are good. So I pulled the valve covers off and what do I find??? The valves dont shut all the way. The heads are shaved .025 so it made since to me to buy push rods that are .025 shorter than factory. Is this a mistake or did the machine shop cut more than I asked them to? I also installed ls6 valve springs when I put it together. Could the spring height be that far off that there isnt enough spring pressure to go agains the lifters? What is the spring height suposed to be?
Thanks
#2- If the valves aren't shutting, you're not going to have any compression on that cylinder.
The pushrods aren't going to keep your valves from closing. The spring in the lifter is much weaker than the LS6 valvespring, so you would just have more preload if the pushrods are too long.
Also, not TQ'ing the rockers while the lifter is on the base circle of the cam can also cause this problem.
"1) The only way to properly check (and know where you are in the travel) is
to use a special checking lifter or completely compress a stock lifter.
a) Checking lifter consists of a lifter that has been disassembled
to install shims that lock the plunger at the top of travel in the lifter body.
If using this method you would add length to the checking pushrod to put the
final pushrods into the middle of travel of the plunger.
b) Using a stock lifter, you must make certain that you have pumped
all the oil out of the lifter. To do this leave it at valve full open (highest
spring load) for a while with an indicator on the pushrod side of the
rocker. Watch to see when the indicator stops moving (when the plunger is
fully compressed in the lifter body). Once you have compressed the lifter
rotate the engine to close the valve, extend your checking pushrod to full
length. Using this method you will subtract length from your checking
pushrod to put the final pushrods into the middle of travel of the plunger.
2) Typical plunger travel on Gen 3/4 lifters is 0.150 - 0.200 depending on
the manufacturer, year, etc. We recommend 0.075-0.100" from the bottom of
travel (using method 'b' described above) or 0.075 from the top of travel
(using method 'a' described above). That will generally put you close to
the middle of travel. While there are many different strategies for where
to put the plunger, for street use we strongly suggest that near the middle
of travel is the safest for durability.
3) The more precise method of checking is 'a' because you are not guessing
that you got all the oil out."
I will look into this over the weekend
Also, I'll ask again, do I need to be concerned with spring hight when changinf from ls1 to ls6 springs?
Like I said, the pushrods aren't going to hang the valve open.
The TDC method is NOT always accurate. Try the EO/IC method to check pushrod length. I have posted directions on this forum numerous times... Here it is again:
FWIW, EVERY cam install I have done using the LS7 lifter with a cam with greater than .600" lift (read smaller base circle) AND stock heads w/GM MLS gaskets has taken 7.425" pushrods for ~.050"-.060" preload. We measure lifter preload on each and every cam install we do. I have never had a lifter failure nor do we end up with the dreaded "sewing machine" noise.
Its very simple, If you change ANY of the following:
valve sizes, valve job, head milling, thinner/thicker head gaskets, decked block, cam with an altered base circle, etc... YOU MUST CHECK FOR PROPER PUSHROD LENGTH.
I have helped countless numbers of individuals with this process over the phone, via email, and PM's. I've posted the process on at least 3 occasions.
Here it is again in a nutshell:
1. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
I might not know everything but I will tell you that this method has worked for me year after year cam swap after cam swap. We average 3 cam swaps a week here so you can do the math.
If you are not familiar with the EO/IC method for determining valve events in a 4 stroke engine, its very simple:
For a given cylinder as the Exhaust valve is Opening, the intake lifter will be on the base circle of the cam and lash/preload should be checked for that intake valve.
For a given cylinder as the Intake valve is Closing, the exhaust lifter will be on the base circle of the cam and lash/preload should be checked for that exhaust valve.
THIS METHOD ALWAYS WORKS!!!
Check it using the above method and see where you are.
The pushrods in use are what length?
Stock rockers and rocker stand?
As for the springs, they will develop plenty of force to shut the valve on a non-running motor (checking compression) so the seat value will be more of a question at high RPM.
thanks
thanks
Is there anyway you can post a picture?
Video #1: 1 1/2 turns from zero last, valve opens
http://s12.photobucket.com/albums/a2...ULY2010001.mp4
Video#2: 1/4 turn from zero lash, valve stays shut
http://s12.photobucket.com/albums/a2...ULY2010002.mp4
I appreciate the help guys and hopefully someone can tell me what I'm doing wrong here.
