Reinstalling stock pushrods and rockers
Is this what Im supposed to do?
http://www.youtube.com/watch?v=89o5rLpbCgI&feature=fvw
but for me I just torqued them all down to 22 ft/lbs, turned the motor and torque checked them all again. I also used the red lock-tite too.
When I went over all of the bolts after turning the motor I didn't find any bolts that were not at 22 ft/lbs. Just from my observation you won't reach 22 ft/lbs unless the rocker is pressing against the head/plate so the resistance you get from the compression of the valve spring shouldn't really matter.
Just follow the GM procedure and save yourself a possible big headache later.
I actually have access to all of the GM procedures and parts catalogs... No where have I stated not to follow the procedure and actually I recommended the procedure up above by starting out my post with "^^".
Anyway, the post of mine that you quoted was referring to a rocker bolt stripping its threads (had nothing to do with following the procedure or not). I would think there would have to be upward force from both the pushrod and the valve stem for this to happen.
It doesn't take much to strip aluminum heads before the bolts are fully seated and torqued.
