400whp a4 tsp 5.3 & 224-228r stock exhaust manifold ?
been there done that on stock manifolds. long tubes and magnaflow gained me 35 rwhp. the stock manifolds have such high back pressure you cant run any timing... i didnt read through everypost so i dont know if you decided to get headers or not but i definitely would...
heres what i made on the 228r on a locked converter, un locked, and 100shot. With longtubes no cats an cutout. My heads are milled to 10.75 also. hope this helps
#32
Check this out: https://ls1tech.com/forums/dynamomet...-mild-cam.html
403hp through stock manifolds. That's a stick shift car though, but still shows theirs hope even with stock manifolds.
#34
WOW !!!
thats impressive !
#36
ok i have a set of new prc 2.5 5.3 in my other car . hasnt been started ever and have always wanted to go with a nice set of afrs . its a nitrous motor and im sure the heads would help .
so im going to pull them off that motor use the pushrods and ls7 lifters .
these heads have been milled 35thousants ill be fine with ptv on both the 224r or the 228r cm right ? im planing on using a regular gm mls head gasket .
wait could i re use a set of cometic head gaskets ? they have never been fired but have been torqued , i have gotten mixed comments about this .
and 01ssreda4 im interested in your cam only . let me knw !!
