valve to piston clearance
Old Sep 13, 2010 | 12:57 AM
cfgioja's Avatar
Default valve to piston clearance
Just curious on how to measure valve to piston clearance. i know you cant cut the engine in two or just hold a valve at what you think might be the right height.
I just want to make sure the new high lift cam will clear my pistons.
Old Sep 13, 2010 | 04:46 AM
vettenuts's Avatar
Will the heads be off the car? There are a few ways to do this.
Old Sep 13, 2010 | 08:01 AM
1SLwLS1's Avatar
Clay Method - Heads off
or
Dial Indicator and Checker Springs Method - Heads on
Old Sep 13, 2010 | 12:13 PM
cfgioja's Avatar
The heads are off of the engine.
Old Sep 13, 2010 | 02:39 PM
Jim_PA's Avatar
Get (or make) 2 solid lifters, put some clay on the piston, tighten the head down without a gasket, make 2 revolutions, remove head, measure the thinnest part of the clay, add compressed head gasket thickness, review the results.
Old Sep 13, 2010 | 05:00 PM
cfgioja's Avatar
why do I need solid lifters? will my roller lifters not work?
Old Sep 13, 2010 | 05:05 PM
Jon@Texas-Speed's Avatar
The solid lifter gives you a true measurement. The hydraulic lifter will compress and you will not get the correct number.
Jon
Old Sep 13, 2010 | 05:32 PM
vettenuts's Avatar
I would use your old gasket to do this as no gasket and a tight clearance can lead to the valve hitting the piston.
You can use the roller lifters with a dial indicator, check springs, adjustable pushrod and a very careful touch.
Old Sep 13, 2010 | 05:36 PM
cfgioja's Avatar
How do I go about making a solid lifter if all I have is a hydraulic? If I use a solid one on my hydraulic setup wont the numbers be off?
Old Sep 19, 2010 | 12:34 AM
cfgioja's Avatar
I got a set of testing springs and was able to use my hydraulic lifters. i got the clay thickness with out head gasket. I need to know what the over all clearance needs to be. i will research but any help will be nice. Thanks
Old Sep 19, 2010 | 02:52 AM
Black 99 Bird's Avatar
70 to 80 thou. seems to be the norm.
Old Sep 19, 2010 | 11:33 AM
cfgioja's Avatar
I measured, .06-.07 in with a digital caliper and clay impressions without a head gasket. So including a head gasket I should be right in the .1 ball park, which is good right?
Old Sep 19, 2010 | 08:49 PM
Sounds good!
