oil pump o-ring install on pick up tube first or pump first?
on the oil pump o-ring are you supposed to install it on the pick up tube first or the oil pump first and then slide it in ? i was reading GMhightechperformance.com and they installed it in the pump first. curious on peoples opinions.
LS1Tech Premium Sponsor
Definitely onto the tube first, and then the tube with o-ring into the pump!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
