what to use to plug pass side sensor hole on 241 casting?
I didn't realize this till well after picking up a set of ported heads but the heads can be swapped to either side of the engine. Both of the heads have the sensor port for the ets. What should I plug up the pass side with? I don't remember what my old 853 casting heads did for that or if they were interchangable.
Thanks for you help!
LS1Tech Premium Sponsor
Or, to take the guess work out of it, grab GM part number 12553191
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
