Are patriot dual valvesprings over kill for my little g5x1 cam?
Old 09-21-2010, 01:08 PM
droptopT/A's Avatar
Default Are patriot dual valvesprings over kill for my little g5x1 cam?
ok guys heres the deal im in the process of installing heads and cam in my car i have a set of patriot stage 2 heads with the patriat dual valve spring kit rated at 650 lift are the spriings over kill for the baby cam im going with
lg g5x1 228/232 588/574 114.would i loose hp by keeping the springs or should i step it up to a bigger cam
Old 09-21-2010, 01:33 PM
slt200mph's Avatar
I am running a little smaller cam that yours now and I have Patriot dual springs on it..I am very happy with them and ran another set on a little bigger cam than yours for about 45,000 miles and they were still good when I replaced them..I always run a dual spring set up just for the piece of mind they give me. I work a Chevy dealership and have seen major damage to heads and pistons and worse when a single spring breaks.
Old 09-21-2010, 02:26 PM
LSX Mechanic
Damian's Avatar
Yes. Huge overkill.
The PAC 1218 will take that cam all day long, provide better valvetrain stability and last just as long. A car I built 2-3 yrs ago has about 30-40K on a set of PACs with this cam.
The internet will have you believe you "need" double springs with everything. But that is not the case.
Old 09-21-2010, 04:20 PM
1979rs/z28's Avatar
Originally Posted by Damian
Yes. Huge overkill.
X2 have 20k + on my 1218's with 585 lift. Works perfect, no need to have the extra valvetrain weight for no reason.
Old 09-21-2010, 04:24 PM
BIG_MIKE2005's Avatar
Hmmm, been running them in my combo with a .581/.581 cam for about 50k miles without a single issue.
Old 09-21-2010, 04:43 PM
droptopT/A's Avatar
Yes. Huge overkill.
should i swap the springs out for a set of pac 1218s or should i swap the cam for something a little more agressive to go with the patriot heads the heads are the ones with the 59cc chambers
i like the torquer v2
Old 09-21-2010, 10:58 PM
LSX Mechanic
Damian's Avatar
That cam is a much better cam than the T2 IMO. I would keep it, and run the PACS.
Old 09-21-2010, 11:08 PM
01SS99red's Avatar
+1 on the sinlge springs Im running .589 .595 for almost 10k mi. now and take it up to 6800-6900 rpm all the time street and strip. you'll be fine
Old 09-22-2010, 12:27 AM
Ss98sS's Avatar
but if you are looking to get rid of them i might be interested in the springs got an ms3 cam was looking for those springs let me know with a price thanks.
Quick Reply: Are patriot dual valvesprings over kill for my little g5x1 cam?
