427 Build
Old Sep 22, 2010 | 09:48 AM
ss4chad's Avatar
Default 427 Build
I am in the process of building a 427 stroker and have a question about heads. I have listed the specs that I have acquired thus far with regards to the build below:
427 Darton Sleeved LS1
12.5 comp
4:00 crank
256/264 - 625/625 - 113+4 hydraulic cam
FAST 90
Holley 90 TB
4:125 Dome Pistons
6:125 rods
I want to go with a set of CNC Ported Dart Heads:
250cc intake port - 68cc chambers - 2.08/1.60 intake/exhaust.
My question are:
Is this head to big for this build
What size spring for this cam?
Should the spring be a beehive or dual spring?
Thanks guys!
Chad
Old Sep 22, 2010 | 11:03 AM
Lambert695's Avatar
I may be wrong but im pretty sure those heads will be fine with the 427. i would also go with a dual spring.
Old Sep 22, 2010 | 12:27 PM
KCFormula's Avatar
I'd say those heads are too big for the intake. Put a SuperVic on it, or at least a Vic Jr. so the thing can get some velocity for the heads to use.
Old Sep 22, 2010 | 03:35 PM
CamaroSS22's Avatar
I ran a set of those heads on my 402 with a 90/90 and a cam just a bit smaller then that, and it worked out great. May even want to conisder and ls3 or ls7 top end. Definately go with dual springs.
