help got a question about ls1 oil pump
Old Sep 22, 2010 | 04:33 PM
Michael Matthews's Avatar
Question help got a question about ls1 oil pump
So im about to swap in a cam in camaro here shortly and today i tore apart a 5.3. And where the pickup tube bolts to pump its in the very back and a mfer to get. Does the oil pan have to be dropped? And is the ls1 goin to be the same way or is the bolt connecting those two together in the front and not in the back? And if they are the same whats the best way to get it out and do a new pump bc i have one and was wanting to throw it in while i was at it. But it has been rebuilt not long ago anf still has good pressure. Any help will be appreciated thanks
Old Sep 22, 2010 | 04:35 PM
The pickup tube bolt. In front on ls1? Or back of pump like 5.3 and 4.8?
Old Sep 22, 2010 | 06:49 PM
The motor is in the cat. So i am gonna have to drop the pan a bit aint i?
Old Sep 22, 2010 | 06:54 PM
SOMbitch's Avatar
Yes you will need to drop pan. The front should drop about an inch which should get you there...
Old Sep 22, 2010 | 07:08 PM
00SSLS1's Avatar
Loosen all the bolts to the pan and it should drop bout 1/2" or so. You might have to pry on it. Good luck and becareful with that bolt
Old Sep 22, 2010 | 07:19 PM
Ok thanks. And how should i tighten it back up? U know dealing with all the alignment crap. Do the pan then frnt cover? And the pan gasket shuld be ok to reuse right?
Old Sep 22, 2010 | 07:46 PM
slt200mph's Avatar
Check this link out is even has photos for ya..ya know the ol saying a pic is worth a 1000 words...
http://ls1howto.com/index.php?article=23
Old Sep 22, 2010 | 08:41 PM
Ok thanks
