Ls1 rebuild time
Old Sep 23, 2010 | 11:59 AM
robster's Avatar
Default Ls1 rebuild time
So its time to rebuild. Need some opinions. Im planning on boring it .30 over, wanting a good cam with mid - top range power, but yet streetable at the same time. Im not familiar with cams as far as numbers go so id like some opinions on this.
Old Sep 23, 2010 | 12:35 PM
blsnelling's Avatar
Gonna need a lot more info to help you out. What vehicle? What are you going to use it for? Do you have any mods currently?
Old Sep 23, 2010 | 01:06 PM
robster's Avatar
02 camaro ss. Only mod really is underdrive pulley. Buying long tubes during the build. Im not looking to build a monster, but wanting a beefy streetable build, something that i can drive a distance without worry. Id be happy with 450 - 500hp.
Old Sep 23, 2010 | 01:38 PM
incbed's Avatar
If you still have the factory aluminum LS1 block your not going to be able to bore it .30 over unless you are planning on resleeving the block.
Old Sep 23, 2010 | 01:46 PM
robster's Avatar
Really. Didnt know that. Can you bore it any?
Old Sep 23, 2010 | 01:57 PM
blsnelling's Avatar
450-500 RWHP without FI is quite a lot.
Old Sep 23, 2010 | 02:11 PM
robster's Avatar
Not really.
Old Sep 23, 2010 | 02:15 PM
Cold Zero's Avatar
With what you are looking for you need to spend alot with good heads like ( Trick Flow 215s AFR 215s, PRC 215s ) with a cam that I don't think will be more streetable ; bucking and choopy idle !!!
You can have great power under the curve with such a mild cam and PRC LS6 / 5.3l heads with resonable price
Old Sep 23, 2010 | 02:17 PM
incbed's Avatar
Really there is no need to bore the cylinders unless you have cylinder wall damage if not then just hone the cylinders and install new rings on your pistons.All the LS1 blocks I have seen the cylinders still have the factory cross hatching.
Old Sep 23, 2010 | 03:03 PM
robster's Avatar
Cool. So me not knowing cams other than whether they sound good or not, what abt a ms3 with just bolt ons and just getting my heads reworked.
Old Sep 23, 2010 | 03:22 PM
needtransam's Avatar
yeah im with you on this one, i want a streetable nice car, not a monster i was thinking port/polish my stock 241 heads, port my ls6 intake and port everything, get some new lifters, rockers and pushrods
Old Sep 23, 2010 | 03:45 PM
blsnelling's Avatar
450-500 is pretty monsterish out of a 347.
Old Sep 23, 2010 | 03:49 PM
incbed's Avatar
Your not going to make 450-500hp with just a cam and factory reworked heads,,unless you spend the money to have your heads CNC'ed and milled ,but your still only looking at around 425ish hp to the wheels unless you tell the dyno guy you want 450hp
Old Sep 23, 2010 | 04:56 PM
robster's Avatar
Id be completely fine with that. Nice sound, new motor, and plenty of power if i feel the urge to play
