Heads for 2001?
Old Sep 26, 2010 | 10:12 AM
Bill Bowling's Avatar
Default Heads for 2001?
I am looking to sell my car and wanted to remove the ported Dart Heads and replace them stock heads. 241 heads were removed. What other heads numbers can I use?
Bill
Old Sep 26, 2010 | 10:15 AM
blownws6_nc's Avatar
853, 243, 317. 5.3 truck heads also.
Old Sep 26, 2010 | 10:24 AM
Will 862 heads work?
Thanks.
Bill
Old Sep 26, 2010 | 10:29 AM
garygnu's Avatar
you should put 241s back on it .you can get them for $100 and they are better flowing then 853s.stock 5.3 truck heads would really hurt power.
Old Sep 26, 2010 | 10:31 AM
Where can I get 241's for $100?
Bill
Old Sep 26, 2010 | 10:34 AM
zacht's Avatar
check the classifieds. ive seen plenty of them selling cheap there!
Old Sep 26, 2010 | 01:18 PM
Thanks. I did find a couple fro $200.
Bill
Old Sep 26, 2010 | 08:12 PM
bww3588's Avatar
any LS head will work. stock 862's will hurt performance unless they have LS1 valves installed.
as far as the 853 and 241 head flow, they are nearly the same. all LS heads (with the exception of 243's and LS3/L92 ect...) flow nearly identical. if you swapped a set of 241's in place of 853's, you wouldnt see any difference on the dyno, or track times. its that marginal.
