best street 400 rwhp cam?
Duration and ICL really determine PTV since max lift occurs near BDC.
The MS cams and Trex are about as big as you go with an unmolested motor but they are not even close to DD friendly w/o supporting mods like gears/stall IMO.....
Like stated a high 220-low 230 cam can be DD friendly with a good tune. I could have easily DD my old 230/234 cam in my 346.
As already suggested a TR230 or TR228 cam. IMO I would stay away from something like the MS4. Yes you might have 400rwhp but your torque is going to suck. You can get 400rhwp out of a 230 sized cam but have way more low end. I would rather have 400 rwhp and torque than 410rwhp and 350 ft lbs.
Best bet is to have Pat G spec you a cam or call Geoff at EPS.
i just went thru all of this I went to the dyno section in here and looked at the cam only section and read all the post and the one thing that I did see is the the T REX cam will get the job done over and over it has made better than 400 hp in a stock ls1 with a ls6 intake and headers and a good tune and yes you will need to put some gears in it but bang for your buck this will get you there and if you call Thunder racing and go to there web site you can see dyno numbers on this cam and talk to them you dont have to fly cut but if you miss a gear and over rev it its going to need to be fixed and it has a nice radical idle go to youtube and type in trex and check it out
Why is there only one mention of power under the curve in this thread???
Wouldn't a 54-444-11 Comp cam be a much better street cam than a MS3?
I am real interested in power under the curve, not peak hp these cams make.
What difference in peak hp could there be?? 10hp?
well I will have 7/8 long tube headers. ls6 intake with ported throtle body. cold air intake. I should have mentione my car is not an fbody. its actually a rx7 and it come with 410 gears from factory and its irs. so dont know how much power loss it will have trought the rear end. I did think of the ms3 and have been leaning towards it quite a bit but I'm going to look into a spec cam from either eps or pat g
Internet Mechanic
Dont know about a MS4 for a daily driver. Read on here that it can wear out the springs really fast - Magic Stick V.4 239/242, .649"/.609. Lot of lift and you will need some really good springs - PRC dual valve springs would work. Plus on a stock setup you will have to flycut the pistons.
Internet Mechanic
LS1TECH & Trucks Sponsor
You don't need one of these monster cams to meet the original goals you specified. You WILL tradeoff drivability and bottom end. Yes, good tuners can make anything drivable, but the huge cams are still huge and are not the BEST for both drivability and being able to meet the goals you laid out. The goals you laid out as well as your current setup does not lead me to the biggest cams. I would still recommend you something in this range: http://sdparts.com/details/scoggin-d...-center/sd0130
Some setups need custom specs, but most of the cam only and heads/cam setups have been done so many times and what works the best has been proven and tested so many times that the cams make it to shelf stock status based on the fact that they have proved themselves to be the best. The term "custom spec" is a bit of a misnomer that gets thrown around alot. Off the shelf cams are simply custom spec cams that have proven themselves in the basic setups, so they are obviously the best choice for someone doing a common cam only or heads/cam build.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
#39
I love this cam. Mine made north of 400 also! As far as power under the curve, who the hell cares? I mean when you pull up next to someone on the highway at 40mph are you going to leave it in 4th and hit it?
#40
If I got another cam, to be honest I would check with EPS, some of their grinds have been putting out sick #'s I don't have faith in reverse split cams. IF I wanted Max effort stock cube/head LS1 the TRex is a proven cam time and time again.
I had a Fast 90/90 (ported) on this car but performance was hurting (should have left it UN ported by Vengence). Either I will do a different H/C on this car and pray the bottom end never grenades (46k on the clock), or toss a 100-150 shot on and just have fun. We will see.
