Heads/Cam (243's/TR230) Dyno day 10/19/10! ~ Track results here!
Old 10-19-2010, 09:45 PM
  #81
caseypryan's Avatar
Old 10-19-2010, 09:51 PM
  #82
Engine_HP's Avatar
Goody Good.
Old 10-19-2010, 09:54 PM
  #83
caseypryan's Avatar
thank you. ported tb and u/d pulley coming soon to hopefully hit that 400..
Old 10-19-2010, 10:15 PM
  #84
Titanws6's Avatar
Good results, agreed on the the TB and pulley, it will probably put you at 400. Gotta like the reverse split cams, nice flat torque curve, no need to rev it to the moon to be in the power. I higher gear will really waker her up to. Congrats!
Old 10-19-2010, 10:29 PM
  #85
caseypryan's Avatar
forgot to mention in my mods I have 4.10's already
Old 10-19-2010, 10:35 PM
  #86
King Nothing's Avatar
still on the stock injectors? nice numbers!!
Old 10-19-2010, 10:45 PM
  #87
caseypryan's Avatar
yup tuner said the stock injects were fine. the a/f ratio would have been going lean around 6000+ if it needed the bigger injectors
Old 10-19-2010, 10:52 PM
  #88
02sleeperz28's Avatar
Sounds and looks good. Nice numbers. Have you gotten on it yet? If so, how does she feel? Any more mods to come in the near future?
Old 10-19-2010, 10:54 PM
  #89
caseypryan's Avatar
yeah the car feels amaazinggg. Eases right into all the power and pulls hard. over 6000 I have no traction with my 275 kdws which is expected. 2/3 shift feels ridiculous haha very happy with it
Yeah just little things though. Ported tb and under drive pulley
  #90
caseypryan's Avatar
and i'll probably run a short belt at the track
Old 10-19-2010, 10:58 PM
  #91
Oh ok nice car again man.
Old 10-19-2010, 11:21 PM
  #92
caseypryan's Avatar
thanks! I'm just happy about the curve. 300rw torque at 2500 rpm
Old 10-20-2010, 12:29 AM
  #93
nice!
Old 10-20-2010, 01:55 AM
  #94
TXZ28LS1's Avatar
casey thats with no LS6 intake, no pulley, or ported TB and the heads are not ported right?
Old 10-20-2010, 04:29 AM
  #95
01ssreda4's Avatar
You need injectors.
Old 10-20-2010, 10:11 AM
  #96
caseypryan's Avatar
I did end up doing an LS6 intake last minute. But everything else you said is correct.
Originally Posted by 01ssreda4
You need injectors.
I already had them and was going to switch them out. The tuner said he has plenty of fuel to work with. It didn't need them..He could see on the dyno.
Old 10-20-2010, 12:09 PM
  #97
01ssreda4's Avatar
Stock injectors are good for stock power. Running an injector into the 90% is not a good thing.
Old 10-20-2010, 12:13 PM
  #98
camz28arro's Avatar
stock 28.8lb injectors should be fine under 400rwhp.
Old 10-20-2010, 12:15 PM
  #99
01ssreda4's Avatar
OK, whatever you say. And BTW OP, those numbers are shitty IMO.
Old 10-20-2010, 12:17 PM
  #100
camz28arro's Avatar
Nvm, just saw he is a 2000, so he has the 26.4 lbers, I agree he should get some 36 injectors.
Quick Reply: Heads/Cam (243's/TR230) Dyno day 10/19/10! ~ Track results here!
