Compression Test
Old Oct 5, 2010 | 12:17 PM
armkneez8's Avatar
Default Compression Test
Recently, my car was sputtering and backfiring. I thought it was a clogged coil or injector because I got a missfire code on #7. I know Compression readings should be in the 160 range on a stock LS1. I went ahead and did a compression test. My number 7 was at 30. I was shocked! I still can't believe I was driving my car in that condition. So now my question is: Is it worth fixing my issue or buying a used block? I have a friend who is selling a used motor for $1,300(80,000Miles). I dont want to spend too much money. , Thanx!
Old Oct 5, 2010 | 01:39 PM
massls1guy's Avatar
I would pull the valve cover and look closely at the springs on #7, that would be the cheapest fix anyway. Then maybe buy/borrow a borescope to take a look through the spark plug hole and see what's going on.
Old Oct 5, 2010 | 04:39 PM
armkneez8's Avatar
Ill try that. Thanx
Old Oct 5, 2010 | 04:44 PM
SOMbitch's Avatar
Hope your piston doesn't look like my #7
Old Oct 5, 2010 | 04:46 PM
bjamick's Avatar
Yep check your valvetrain to make sure it's not something up with it.
Old Oct 6, 2010 | 12:23 AM
Whiteaw57's Avatar
Geez what happened to that piston....
Old Oct 6, 2010 | 07:29 AM
ctd's Avatar
ctd
unlucky #7, I've been searching the **** to try & understand the consistent failure.
Old Oct 6, 2010 | 08:26 AM
armkneez8's Avatar
^^^I've been seeing this constant problem. I'm buying a used engine for now.
Old Oct 6, 2010 | 12:54 PM
armkneez8's Avatar
Does anyone know what it would cost to fix the issue(if it is the piston)?
Old Oct 6, 2010 | 01:08 PM
Always2Slow's Avatar
Depends on the extent of the damage. If the cylinders are barely scratched up its worth rebuilding to a 347 and would cost roughly the same. Plus you would have a stout bottom end.
