Rpm's
Old Oct 18, 2010 | 02:48 PM
Cold06's Avatar
Default Rpm's
Searched and searched for the answer what can a stock LS1 handle is 6000 rpm it? All i can find is 7000 is max for stock bottom end PLZ HELP
Old Oct 18, 2010 | 02:50 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
We usually set our rev limiters around 6800 RPM for the stock bottom end. The stock rod bolts typically don't do well with anything over 7000.
Old Oct 18, 2010 | 02:53 PM
blsnelling's Avatar
6000 is a day in the park for a LS1 bottom end.
Old Oct 18, 2010 | 02:59 PM
Cold06's Avatar
what about the stock top-end will it handle 6800?
Old Oct 18, 2010 | 03:01 PM
blsnelling's Avatar
Push rods should probably be replaced. Rocker arms are fine. Not sure about stock springs.
Old Oct 18, 2010 | 03:13 PM
Cold06's Avatar
I'm looking into the VXR5 cam, springs,push rods, PP tb, LS6 intake but i wanted to know what the stock topend could handle
Old Oct 18, 2010 | 05:28 PM
Cold06's Avatar
anyone??
Old Oct 18, 2010 | 06:07 PM
KCS's Avatar
KCS
Moderator
Originally Posted by Cold06
anyone??
Depends on a lot of different variables. The parts you listed already changes what RPM the "top end" can handle and "safely" is open to interpretation as well. Just go with 6800RPM and leave it at that.
Old Oct 19, 2010 | 07:16 AM
Cold06's Avatar
I understand that but i really need to know what the stock top-end can handle
Old Oct 19, 2010 | 07:55 AM
01ssreda4's Avatar
Stock springs are crap. Stock pushrods are crap. Don't spin to 7k.
Old Oct 19, 2010 | 03:17 PM
Cold06's Avatar
I need a number!!! Lol 6100,6200,6300,6400,6500,6600?
Old Oct 19, 2010 | 03:41 PM
KCS's Avatar
KCS
Moderator
There is no definite answer.
If it makes you feel better, I'll say 6500RPM.
Old Oct 19, 2010 | 08:29 PM
mtuggle86's Avatar
If you have a 2001+ car your engine has the same rod bolts as the LS6 which was introduced in 01. That engine in the Z06 was rev limited at 6600 from the factory so imo its safe to say an 01+ ls1 shortblock can handle at least 6600 for a long time. Im setting my rev limiter to 6800 with my new cam.
Old Oct 19, 2010 | 08:41 PM
Cold06's Avatar
Ok I guess ill leave it alone for now, and when i cam it then ill jump to the 6800
Old Oct 20, 2010 | 08:23 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
I would not rev the stock valvetrain more than 6300. Those springs are not very good.
I would not rev the stock rods over that either, if you had the stronger LS6 style bolts and valvetrain, you could go to 6800. GM engineered the LS6 vavletrains to be stable to 7000 for any overrev or missed shift.
