Need help guys!!!
To do this you take your torque wrench you bought from autozone, attach your 1/2" drive 15mm socket to the wrench. Set the torque to 18 lb/ft.
If you bought an electronic torque wrench you will push the button with the "+" symbol till it reads 18, not 180, but 18. If you have the older style twist then you twist it till you go past the 15 lb/ft mark but stay less than the 20 lb/ft mark.
You then take the wrench and angle it so you can get the 15mm socket around the bolt which has been threaded in by hand. Now go clockwise to tighten and tighten the bolt till it, beeps, clicks, bumps, jumps, or yells. (whatever noise or sound your torque wrench makes) If it makes any of those noises you are done, no more tightening of the bolt is needed.
n whts up with tha guy makin fun of my forum name? coolstarrybra... stay tha *** out if u cant help me...
so i got all the oil in... moment of truth 2 see if she purrs right...
no1 answered me tho, should i use a TQwrench on the oilbolt to keep it from fallin out? or will it be fine if i use my fingers
And I might be from the internet's **** hole but it smells way better than LS1tech and its way more interesting. Why dont you just drive your HurrMaro off a cliff.
it started this mrnin real quiet but it sounds like a bunch of marbels fell into my throttle body n r hitting **** or somethin... she aint purrin right...
Wht do i do?? should i drive on her to c if tha sound goes away when all my mobile1 gets all mixed into tha engine parts?
let it idle for a minute, if this does not fix it, then you need to take it to a shop. Although you don't trust them, right now I would not trust your work, just being honest man.
Wht should i add to make this noise go away? its fukin annoyin...
What exactly do you drive?
I also don't go online to try and look cool...
Maybe you should get out more slugger.
yall r real paschent for helpin me with this. i appreciat it, even if yall do hate on 13sec imports...
This jerkoff
