In The market For some Heads
The patent answer on this site for a good daily driver cam seems to be the Thunder Racing 224 cam (224/224 .563/.563), or something similar.
with TFS in a DD?
The PRC 215s just have better p/v clearance for larger camshafts when you get the compression up.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
The TFS heads have about .050" more P to V than a stock GM head with the same 2.04" valves, so that's a pretty good amount of clearance in my book.
I know lots of guys who have run upper 230's at .050" cams with 59-60 cc TFS heads without issues.
You should not have a problem with any cam you choose.
(Hint: it's You're)
