Tore the heads off today to fix Cometic... look at pics
Some may remember my flutter noise I thought long ago was a header gasket leak. It revealed itself by pushing into the overflow not long after. So today was teardown!
First picture is of orange looking crust (rust) on the center two bolts in the head. Seems I have seen other LS pictures with it in there. What is it or causes it?
Here is the flutter! Looks like the inner ring delaminated and was hanging out there. You can see where the gasket is black to the outside (no Copper spray still there) where it had been pushing out under RPM and into that coolant passage on the head side.
Wouldn't hurt to spray something on there before putting the intake on, I have heard of water getting under the intakes and causing bolts to rust, etc. It also caused issues with knock sensors if I remember right.
