valve tip wear??
Old Nov 1, 2010 | 01:24 AM
samsel450r's Avatar
Default valve tip wear??
well i took my valve cover off to replace the gasket on the drivers side and notice this.. thats the only one that looks like that. the heads are afr 205's. what would cause this? and why to only one valve?
[IMG] Uploaded with ImageShack.us[/IMG]
Old Nov 1, 2010 | 07:05 AM
vettenuts's Avatar
Did you check the wipe when assembled? Looks like that valve may have worn down as the valve stem is mushed down pretty good. You should see where the other valves were contacting the heads and have the valves check for hardness. What heads are those?
Old Nov 1, 2010 | 08:16 AM
Steve Gunn's Avatar
Almost like the one spring is too tall somehow... Is there something wrong with the base or it's seat??
Old Nov 1, 2010 | 08:37 AM
Duffster's Avatar
any chance the rocker wasn't torqued properly and pushed forward and bent the bolt?
Old Nov 1, 2010 | 08:40 AM
01ssreda4's Avatar
I think, since its such an isolated problem it may be an issue with the valve itself.
Old Nov 1, 2010 | 01:47 PM
samsel450r's Avatar
i didnt install the heads i just bought the car like 2 months ago. and the heads are afr 205's.
Old Nov 1, 2010 | 02:10 PM
dudeiwin86's Avatar
heads are coming off.
needs a new valve, retainer and lock at a minimum
cause?
-bad valve is possible, but im doubting it because that usually happens in batches, and chances are yours all came from the same batch
-incorrect rocker installation/shimming/whatever
-too much lash... possibly valve float
you can see the retainer has rotated... valve float comes to mind, but i dont know how much rotation is "normal"... if any at all...
the damage to the retainer and keepers was caused after it mushroomed the valve.
i have the car towed to a professional with it still assembled and let them check spring pressures, seat pressures, lash, preload etc etc etc so you can find the cause so its not repeated on reassembly.
Old Nov 1, 2010 | 02:56 PM
vettenuts's Avatar
OK, stop there. Contact AFR. Not sure on your particular heads but there was an issue with soft valve stems a some AFR heads a few years back. AFR took care of the issue. Hard to believe there are any still around that haven't been corrected. Can you get the history of the heads from the prior owner? Once you break through the thin hardened layer you will have this issue.
Old Nov 1, 2010 | 03:27 PM
NHRA4MULA's Avatar
{+ 1 on contact AFR just one valve sounds like what he said or guide problem .....did you pull the other valve cover
Old Nov 1, 2010 | 04:35 PM
massls1guy's Avatar
The springs do rotate. Looks like the retainers do too:
http://www.youtube.com/watch?v=019Jyn9oB5k
Old Nov 1, 2010 | 05:15 PM
dudeiwin86's Avatar
10/4. i knew they rotated when floating. was never sure about under "normal conditions"
thats a cool cutaway vid
Old Nov 1, 2010 | 07:34 PM
01ssreda4's Avatar
Valves rotate under normal conditions
Old Jul 1, 2012 | 10:28 PM
joemal's Avatar
Default afr 225 heads
I got a 04 gto with a 402 that slp bilt with afr 225 heads and all the valve stems are wore down, got two that isn't and did a swipe test and they swipe fine! i'm waiting for afr to call me back and i also heard they had a valve hardness problem.
