do I need a tune for this cam?
Old Nov 3, 2010 | 10:36 PM
firechicken76's Avatar
Default do I need a tune for this cam?
LS1-GT2-3
207 / 220 .571" / .578" 1.7 ratio 118.5
Im going to get this tuned when i install the blower, but id rather not do everything at once.
so yea, would it be safe to run? or even get on hard?
Old Nov 4, 2010 | 01:07 AM
cadenwade's Avatar
Yes i would deff put at least a base tune
Old Nov 4, 2010 | 01:29 AM
i cant just drive the car around with it like that? how about a mail order tune? im just looking at expenses, because I plan to get a full tune with the blower install.
Old Nov 4, 2010 | 01:40 AM
cadenwade's Avatar
yea a mail order will be fine and be the safest bet for you
Old Nov 4, 2010 | 05:01 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You may not know what your A/F is though after the fact, or what duty cycle your injectors are reaching. I drove a 222/226 cam for 4 months untuned on a completely stock setup minus valve springs and pushrods. We did a baseline pull on it and then a tuned pull and it was like a 19rwhp difference once we got the bugs worked out and the fuel right. Mail order would work, but the more you do to something the more its going to need a finer toothed comb pulled through it. Feel me?
From my own experiences I didnt mess anything up and I romped on it quite a bit. Not that I suggest everyone do that, but most people can feel when they are reaching their limits or when its not smart to drop the hammer on the throttle. If you are conscious about it being untuned you probably will take care of it sooner than later. Look at it this way though. You will need a good tune later on and I wouldnt get a mail order tune for a FI application. (No offense to the mail order guys). Get the full tune now and go back for a retune as you piece it together. Some places charge 25$ for that if not free in some instances.
@ -23.5° degrees of valve overlap.....no one will even know you have a cam in that car.
Old Nov 4, 2010 | 08:32 AM
thunderstruck507's Avatar
Every cam needs a tune.
Period.
One of my best friends put a 98 ls1 cam in his 01 T/A when the engine threw a rod because it was almost free and was a little bigger. His car has worse manners than my car did on a poor mail order tune. It is a pain to start, sounds like it's loping, and hates to idle.
Old Nov 4, 2010 | 09:05 AM
NVR_SPDS's Avatar
I don't know what your tuner offers, but mine offers discounted rates on retunes.
Old Nov 4, 2010 | 12:51 PM
what kind of prices do you have?
i will get the car tuned soon after the cam, i just dont want to do the fuel pump, cam, and blower in the same weekend. id rather split them up.
Old Nov 4, 2010 | 01:58 PM
NVR_SPDS's Avatar
My tuner charges 500 for the original tune, then an hourly rate for retunes. Think its a little over 100 an hour.
I would do the pump then can and tune then blower/ injectors and returned.
Old Nov 4, 2010 | 02:00 PM
i wonder what it would cost to tune the blower, i mean how many hours. good idea though.
