mid range cam question
Old Nov 4, 2010 | 05:46 PM
DaveX's Avatar
Originally Posted by z99ls1
Another thing I though I seen on one of the cam swap guides is that you don't have to adjust each rocker and turn the motor over like the lt1. it says you just put the rocker on and tighten it down to 22ft lbs? Is that right? If so wow thats easy...
That is correct but logic tells me that you should not be compressing the spring when you are torquing the rocker to set it to the proper torque. I turn it over by hand while I am doing it and torque them when the lifter is on the bottom of the lobe. You can do several at once this way.
LS1's make great power. I agree 224 - 228 is the range cam you are looking for. I do think you will want a slightly higher stall though.
Old Nov 4, 2010 | 05:48 PM
DaveX's Avatar
Hopefully you have either a 3.42 or 3.73 gear also.
Old Nov 5, 2010 | 06:26 AM
z99ls1's Avatar
Restricted User
3.23's
Old Nov 5, 2010 | 06:33 AM
garygnu's Avatar
you don't have to lower your oil pan to install the timing cover.
Old Nov 5, 2010 | 11:09 AM
PREDATOR-Z's Avatar
Pick the cam first and according to its powerband pick the stall with the right shift extensions.
LSA should be picked taking into consideration exhaust setup and power band desired.
I would say between 3000 and 6200 rpm.
Something like a 228/232 111+2 LSA with the right lobes. 8* overlap
Old Nov 5, 2010 | 01:54 PM
z99ls1's Avatar
Restricted User
I was thinking the 3200 would prob go with the 228 cam...
Old Nov 5, 2010 | 01:56 PM
z99ls1's Avatar
Restricted User
Would the 3200 stall go good with the cam you mentioned. And what does the +2 on the 111 lobe seperation mean?
Old Nov 5, 2010 | 02:17 PM
MM98's Avatar
It means there is 2 degrees of advance ground into the cam.. This will bring the power in a lil sooner.
Old Nov 5, 2010 | 04:25 PM
PREDATOR-Z's Avatar
What STR will the verter be? Personaly I would not go less than 35/3600 stall. Why, because peak trq will be around 4600+ so unless it is a drag project, I would not go 1000rpm below that to hit he sweet spot of the band.
Old Nov 5, 2010 | 05:24 PM
z99ls1's Avatar
Restricted User
My car shift extension now goes down to 4100 just about, with the 3200 I think it would be at like 4600 or so.
Old Nov 5, 2010 | 05:25 PM
z99ls1's Avatar
Restricted User
and I will have to check with chris at circle d to ask what the str on the 3200 stall is
Old Nov 5, 2010 | 09:32 PM
  #32
toothdoc's Avatar
114 LSA with an auto. 112 with a manual.
Old Nov 6, 2010 | 02:19 AM
  #33
PREDATOR-Z's Avatar
Old Internet myth, with today's tuning specialists, one should choose overlap for rpm power band range desired.
Old Nov 6, 2010 | 06:34 AM
  #34
z99ls1's Avatar
Restricted User
The cam you say here looks like something I would want, but I was looking to order a kit from texas speed or somewhere if I could.
Old Nov 6, 2010 | 08:56 AM
  #35
hammertime's Avatar
Texas Speed or any number of other vendors can grind that cam for you.
http://www.texas-speed.com/shop/item...d=898&catid=44
Old Nov 6, 2010 | 02:03 PM
  #36
z99ls1's Avatar
Restricted User
but a custom cam would probably be harder to get tuned with a mail order tune? Wouldn't the 228/228 with 112 lsa be about the same as the cam you mentioned pred-z?
Old Nov 6, 2010 | 04:25 PM
  #37
BaddBird's Avatar
Another internet myth.
Old Nov 6, 2010 | 05:35 PM
  #38
z99ls1's Avatar
Restricted User
Ok well im positve im getting the circle d 3-3200 278mm stall. So maybe I should ask what cam would go best with it and make good midrange power or 1/4 mile power
Old Nov 6, 2010 | 06:49 PM
  #39
garygnu's Avatar
look at the EPS cams,a car with 3.23 running 11.30.
Old Nov 13, 2010 | 01:45 PM
  #40
z99ls1's Avatar
Restricted User
anyone know what would go with that stall?
