TFS 215 and Pushrod length
Old Nov 7, 2010 | 09:48 PM
got milk??'s Avatar
Default TFS 215 and Pushrod length
Just installed my 215s checked my pushrod length and I got almost 7.4 my checker was about 11 3/4 turns which would put me at a 7.387 pushrod (Zero Preload). I am using LS7 replacement lifters. I have a set of 7.5 pushrods that came with the heads. I slapped them on spun the motor around to check using the EO/IC method. I got about 1 3/4 turns on my intake valve to 22ftlbs and almost 2 complete turns on my exhaust valve to 22ftlbs. With that being said I know I could possible go slightly shorter but I took everything off and checked my wipe pattern and it was dead center. BTW I am using Harland Sharp roller rockers. Just trying to get a feel with some of the other TFS people are using and if using my 7.5s is too much preload for those lifters. The heads are TFS 215s milled to 61cc I am using GM MLS gaskets. The cam is TSP Torquer V2.
Old Nov 7, 2010 | 10:11 PM
Ws6kid.'s Avatar
Hey man seems like you know your stuff about ls1's i just got a set of TFS 215 heads maybe you can help me out with pushrod lenght and cam and other stuff if you dont mind?
Old Nov 7, 2010 | 10:40 PM
got milk??'s Avatar
If you need anything just let me know I have done a few cam swaps in my garage. This is my first head swap so I will let you know how it goes. I am just hoping that these 7.5 wont be putting too much preload on my lifters and grenade them.
Old Nov 8, 2010 | 02:19 AM
flintwrench69's Avatar
I had to go with 7.550 as I only got 1/4 turn with the 7.5s but I only had the heads milled .010 with GM MLS gaskets & YT 1.7s. You might have a little too much preload, 1 turn is .050 & the LS7 lifters like .080 preload. Your valvetrain should be quiet though.
Old Nov 8, 2010 | 02:30 PM
got milk??'s Avatar
your post is one of the ones I was looking up while I was doing my install. I also was checking out the one from the other guy who ended up with really short pushrods. I was second guessing myself constatly during the measuring because of all the different people using trickflow heads and all the different pushrod lengths. I am going to end up using these 7.5s for now and see what happens. I will give an update after everything is buttoned up.
Old Nov 8, 2010 | 03:25 PM
SOMbitch's Avatar
TFS 220's, 60.5cc with GM MLS, LS7 lifters, 7.5 PR's and deadnutz quiet here...
Old Nov 8, 2010 | 03:53 PM
Darkman's Avatar
What rockers?
Old Nov 8, 2010 | 07:22 PM
SOMbitch's Avatar
Originally Posted by darkman
what rockers?
Yella Terra UL
Old Nov 8, 2010 | 07:24 PM
JaSSon's Avatar
got milk, whats your compression on that setup?
Old Nov 8, 2010 | 07:52 PM
Darkman's Avatar
Yella Terra UL
Thanks.
Old Jul 30, 2011 | 05:04 PM
neals98's Avatar
Yella Terra UL
I know this is old but how much did you have to shim them?
Old Mar 11, 2013 | 10:28 PM
barracuda_440's Avatar
My TFS 235s with 7.5's took almost 2 full turns with 7.5's...
Old Jul 31, 2013 | 12:44 AM
got milk??'s Avatar
Just to give an update on everything since it was bumped. With the 7.5 pushrods and my heads milled to 61cc everything was perfect. Quiet as a H/C valve-train can be. Since then I removed all the go fast goodies and sold the Z28. Ran it complete for about 7500 miles.
Old Aug 11, 2013 | 12:05 PM
LASTOFTHEBREED02T/A's Avatar
Thanks for updating. I was looking for an answer to what pushrods to use with my TFS 235 milled to 64cc using yella terra UL rockers. Looks like the 7.5 do the trick, now just a matter of who to call n order.
