compression question
Old Nov 14, 2010 | 10:37 AM
BIGB4015's Avatar
Default compression question
Can some one tell me what the compression ratio would be on a stock bottom end LS1 with a 64cc head and a 0.40 cosmic head gasket?
Old Nov 14, 2010 | 04:49 PM
ShevrolayZ28's Avatar
From the post linked below I see Tony Mamo from AFR stating that 63cc with 0.040" gasket is 11.0:1 SCR... so with a 64cc chamber I estimate that you would be right around 10.75:1 SCR...
https://ls1tech.com/forums/generatio...rations-3.html
Or you could try googling for a compression calculator if you're still curious.
Old Nov 15, 2010 | 11:39 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
According to the compression calculator I use you would be at 10.86:1.
